Windscreen fitting diy
Old Jul 7, 2012 | 04:52 PM
haz87's Avatar
haz87
Default Windscreen fitting diy
Anyone done it. Did the rear tailgate glass by myself no problem. Is the windscreen in essence the same job (is the rubber the same design).. just slightly larger? Or is there more to it?
Old Jul 7, 2012 | 10:06 PM
neil73's Avatar
neil73
When I refitted mine i had some one to give me a hand,I put wire inside the rubber and got the second person to gently push on the screen while i pulled the wire out, pretty easy really
Old Jul 7, 2012 | 10:12 PM
caboking's Avatar
caboking
I was a w.screen fitter for 7 years for the RAC until recently so can give you some advice if need be. What car is it and what window you fitting?
Old Jul 7, 2012 | 10:14 PM
7sean7m7's Avatar
7sean7m7
Just make sure you have loads of washing up liquid that's my advise. Ive done it and if the string keeps smapping it can really rag you off. We used crabbing wire in the end
Old Jul 8, 2012 | 12:02 PM
haz87's Avatar
haz87
Cheers guys.
Caboking its a mk4 escort - windscreen
Old Jul 8, 2012 | 12:28 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
easiest screen or all to fit
string wound slid it in and pull the string out nice and gentle
my tips hold or tie up the unpulled end of the string because when you pull it can come thru
i wouldnt use washing liquid
slowly round the corners
once you do a few you know how hard you can bash it to get it in faster but sring round and crossed over and just pull it til it drops ino the hole
i'd start the string at the top nearer one corner with the rubber at the bottom already tucked in
Old Jul 8, 2012 | 02:15 PM
caboking's Avatar
caboking
1) You want some sort of cord that is about 5mm thick but no thicker
2) and then fit the rubber to the glass and fit the cord in the groove of the rubber all the way round.
3) Start the cord at the top of the rubber then across and down the side, continue across the bottom but stop in the middle and leave about 12 inches of the cord hanging out of the rubber and tape it to the inside of the glass.
4) Continue across the bottom after taping the cord and this will give you some cord to pull on once glass is in position
5) continue cord up the rubber on the opposite side and meet at top where you started.
6) Once you have the screen in place make sure that any cord hanging is on the inside of the car
7) start pulling the cord from the loop you left at the bottom working to a bottom corner and about 6 inches up one side.
8) Do the same for the other side and this will make the glass central in the car.
9) Once this is done make sure all the rubber at the bottom is lipped over and pull down on the glass to seat the rubber fully home.
10) The next step is to start pulling the cord up one side at a time and about 6 inches across the top
11) do the same for the opposite side and gently tap the glass with your palm to push the glass in if need be and finally pull the rest of the cord you have left and it should pull out completely and lipping the rubber over as you pull it.
12) Check all the rubber has lipped over the appature and hey presto. If you want to aid the rubber then spray some sort of glass cleaner around it that will evaporate but don't use fairy liquid as it will take ages to evaporate and can help future leaks and corrosion.
Phew got there in the end.
Old Jul 8, 2012 | 09:08 PM
Rogeyboy's Avatar
Rogeyboy
Sticky on that?
Sierrasideways
15
Aug 31, 2015 10:10 AM
borboyous
Aug 22, 2015 11:17 AM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
jay030787
Aug 5, 2015 09:28 PM
