Cams
Cams
Hello all,
on one of my RS Builds i bought a Kent cam for the engine years ago, the rev limit is around 5.50 to 5.90 x1000 revs.
i was told that the rev limit is determined by the Cam your using, if so whats the best cam to get so that i can take the revs to 7 - 8,000 revolutions a minute instead of 5,500 per minute.
i've heard of NEWMANS but im not very knowledgeable about these things and its been on my mind as to why the revs arent higher ?
any help or suggestions welcome on this.
Thanks in advance
Thanks in advance
Not too accurate im afraid mate.
Ultimately your con rods will determine your rev limit. If you are on standard rods i would highly recommend a maximum rev limit of 6500,
However, unless (as you say) you have a suitable cam, and a well ported head your power will start to tail off after 5000 rpm, so a rev limit of 7-8000 rpm would be pointless.
Rob,
Rob,
Rob,
Rob,
so its the rods that determine the rev limit ?? the rods in the car are sweedish motorsport H section rods.
is there no way of getting more revs out of it or at least to 7,000 rpm
is it mfi o r efi , if its on a mappable ecu u can have it mapped for more revs , its just if there is any point , if it stops makin power at 5.5-6k whats the point in puttin more stress on everythin reving to 7-8k
thanks for the input. its EFI and it does have a mappable ecu, in your oppinion with Forged H section rods, forged wassners, machined head etc, would 7,000 be ok or would 6,500 be better do you think.
thing is i dont quite understand where you say " if it stops making power " do you mean when the limiter comes in ?
if so this is what i want to change, id like the limiter to come it at 6,500 - 7,000 but just trying to get the most out of the engine ?
im not majorly mechanicaly minded and i dont know ratios etc of it all, but from your reply i might look into getting it re set to go to 6,500 - 7,000 area as the rev counter isnt being used past my previous settings lol, in other words whats the point in having a rev counter with red line marking when it doesnt go near it ?
dont get me wrong it is very fast but i would like just that little bit more out of each gear.
Thanks
Balls Deep!
What Stu means by 'not making power' beyond a certain RPM is that you may make peak power (BHP) at say 6000rpm and after that it starts droppping off (bigger turbo needed, more agressive cams, head work, etc..) so there is no point raising your limter above this as all your doing is putting lots of strain on the engine internals and turbo, getting things really really hot, but gaining no power at all....
You will not know how and where your engine makes power without a dyno run, at this point if your tuner thinks you will continue to make power with an increased RPM limit then you do so, if not you leave it.
ok so i will look into someone doing the map for me, i have faith in the rods and pistons ive got.
i just glad to know the limiter can be changed by the ecu and i dont have to buy another cam lol.
Thanks alot this helped massively
advice appreciated greatly, looks like i will talk to a tuner more in depth lol ( opens wallet ) lmao
1.6 Block ( machined , whatever lol )
RS turbo head ( ported, polished, etc )
EFi Manifold ( looks slightly different to a normal one, the throttle cable is in a different position but thats how it was fitted, i think the throttle body might be the reason )
Wossner High Performance pistons ( cant remember the ratio's but they have been machined for low compression)
Sweedish Motorsport H Section Rods ( Shot peened )
P8 ECU ( i got through a mate of a mate who said it's a good management system ,so i'm guessing it can be mapped ? )
Stage 3 Hybrid Garret Turbo ( got it ordered in from Turbotechnics 5 days ago, has 360 deg thrust baring, dont know any ratio's etc will have to check their website again )
Internal Wastgate ( nice flutter on low revs and high pitch squeals on high revs lol sounds great, i think its a 34 actuator but might be no such thing lol )
vernier pully
Kent cam ( cant remember which one etc ratio's )
sierra 1.8 CVH alternater on it
Machined Hybrid 1.8 Wheel.
Magnecor HT Leads ( recently perchased )
Baily Swirl Pot
Bailey Oil Separater
Bailey Header Tank
Samco and Roose Motorsport Hoses.
Rising Rate Fuel pump regulator
Standard Fiesta RS Turbo Fuel Rail
Green Injectors
Competition Fuel Pump
Standard RS Turbo Fuel Filter
3 Bar map sensor ( no idea what this means but was told it has it with the ECU etc )
4 Padel Organic AP Racing Clutch.
It runs fine at the moment, i havent had it rolling roaded or mapped though so no idea of HP, i suppose when i find a tuner he can sort that out !
I dont use it as an everyday car as like i said its been getting bits done for years now and i only take it up the road to run her about every now and then on nowhere roads, but its coming to the point where i need to start finishing her off as id like to get her on the road properly but i just want the revs to do what they are supposed to.
Thanks for the help anyway
oh i forgot some bits, it has GRS intercooler and radiator ( recomended to me by a friend who used to have a quick RS turbo, he said they are expensive lol HE WASNT WRONG !! but it seems they are for heavy duty cooling which i suppose is a must )
Last edited by GROUP A; 12-01-2012 at 01:57 PM. Reason: Missed out Radiator and Intercooler Spec
i bought the cam years ago, its a Kent Cam but for the life of me i cant remeber what sort or with any ratios, i cant even attempt to find a recipt its probably lost lol....but it is a kent cam because i remember buying it, to start with i had to ask people about it, i thought kent cams was a place not an actual cam lmao.
but none the less its a Kent cam lol
The ability for any engine to rev to a certain rpm is dictated by valve spring pressure. the ability to control the valves and keep the lifters following the camshaft profile. In many cases people often assume a low revving engine to be the poor head flow. This is just not true. It is the valve springs losing control of the valves, preventing further revs.
A solid lifter camshaft with correct valve springs will rev well over 7000 rpm with a standard (poor flowing)cvh head.
A poor flowing cylinder head and a short duration camshaft will limit peak power production, but the engine will still rev much higher than peak power.
What valve springs are you running? New Factory Ford ones are better than some aftermarket springs. However, 20+ year old factory springs will not be up to the task in any high rev application.
similar spec to this don't you think??????????
Hello all,
I was wondering from anybody's experience what sort of BHP i will be running out of my Escort with Cossy management.
I have yet to have her in for a power run But was wondering if anybody had a rough idea off the top of their head.
SET UP :
1. Cosworth P8 ECU with Pectel Board Running ALS ( ANTI LAG )
2. EFi Conversion
3. Wassner Forged Rods and Low Compression Pistons
4. Garret T3 Hybrid Turbo with 360 Degree Thrust Barring, Internal Wastegate
5. Skimmed head, ported and polished
6. Cossy Bottom End
7. Coil Pack
8. 27 PSI Boost Pressure ( holds on the button )
9. Green ( 806 ) Cossy Injectors
10. Cosworth Throttle Body
11. Group A Induction Kit
12. WRC Air Injection
13. Magnecor HT Leads
14. Full Stainless 3 to 5 " Rolled out Exhaust System, DE CAT, STRAIGHT PIPE
15. Billet Crank
16. Kent Cam
17. Uprated Valves and Billet Springs.
18. Cosworth Competition Fuel Pump
19. Cosworth WRC Competition Fuel Pump Regulator ( Rising Rate FPR )
20. Cosworth Fuel Rail
21. High pressure Braided Hoses All Round.
22. ProAlloy Radiator
23. GRS Motorsport Intercooler
Hello all,
SET UP :
2. EFi Conversion
6. Cossy Bottom End
7. Coil Pack
15. Billet Crank
16. Kent Cam
Hello all,
SET UP :
2. EFi Conversion
6. Cossy Bottom End
7. Coil Pack
15. Billet Crank
16. Kent Cam
Hello all,
SET UP :
2. EFi Conversion
6. Cossy Bottom End
7. Coil Pack
15. Billet Crank
16. Kent Cam
when i got my ecu after i had started building the engine i was told to go EFi, it seems this guy has quite alot more than me in turms of parts but yah its sort of similar to my one but without half the parts also to my knowledge the valves and springs in my engine were just cleaned not upgraded
i just did a bit of searching on the net, anyone know of a good tuner who could look at this rev limit set i need sorting.
i left a message on the page of the person with that spec rmnlwln or something with the spec you posted, nice colour car, yah looking at the engine pic hes got i can see straight away i have the same Inlet manifold but the other parts are different, not too far off but not exact. He must of spent a few quid lol billet cranks are over a grand alone arent they.
all im after is to get somewhere repretable to set my revs properly as long as my Kent cam does the trick ill be happy but lets see what he sais when i get to doing it.
Yah the springs are just standard i think, ill look into this also, i got my pen and pad out now.
so its worth looking at the springs and stuff aswell, are they expensive ?
alaso if i change them its going to effect anything else other than the revs, ie change how the ecu reads the car as it runs at the moment ?
http://forged-pistons.co.uk/
Last edited by GROUP A; 12-01-2012 at 02:05 PM. Reason: added sentence about web search
what the FUCK is a D4 RST ?
why do you need to see picures, the engine is sealed im not going to take the engine apart just to take a photo of the cam for you am i you PRANNY !!
i been opn here a couple of days and have a guy called luke and you talking to me like a peice of shit and insinuating im some other c**t, what the f**k is your problem ?
for your information i will get pictures of my car but not for you, but for my profile, ill even throw some in of my jag for good measure eh ? sort yaself out chap
lol , i dont have a problem maybe u are the 1 with the problem , thats why u are on your 3rd user name
, 1 your cam is years old as u said and 2 its a kent which wear quickly and a lot of peole have problems with them , so its probly fucked so u need to get a new1 if u want power and to rev it , i asked to see pics of the car and engine cos im interested , i dont want u take it to bits ???? not really interested in your jag tho
D4rst is a legend 80 page thread
you will see picures of my car soon ill take some new ones tomorrow of it on the driveway and of the engine so that you can feed your interest as much as you like, FYI i have hardly driven the car as its been off the road for a while, i been adding bits for years, the only driving ive done is about 3,000 miles with the cam, so regardless of how old it is im sure a cam wont ware down after 3,000 miles wil it ? ive sent you a pm aswell asking about this problem you seem to have with me, because to you and 2 - 3 other people im some other person with 3 names or something?
trust me i do not have a problem mate, i just had enough already of the childish crap that keeps getting fed to me every time i make a post, there are people on this thread for example who have genuinely helped me out and because of other people like you its turned into some sort of bollocks because you " THINK what you THINK ".
i said it in my PM's to other people so i may aswell say it here, either way i'd like to make a post in the future without this shit happening.
1st of all, this rmelntgglnwnl person whatever the f**k his name is lives in Herne Bay, I LIVE IN LONDON !!!
hes 27 , I AM NOT
hes occupation is offshore, I'M A PLASTERER, unless there are plastering jobs offshore but i doubt it somehow.
Yes ok he uses a kent cam in his spec and the same ecu as mine, SO WHAT am i the only one with a p8 in an escort, i have mates that have the same as me for the love of F**k maybe youd like to tell them they are someone they are not ?
ever since i subscribed ive had stupid bloody pm's and questions, everytime i make a post its almost like your trying to make me slip up or something, the only thing i'm slipping on is bullshit, you ask for pictures of my car and engine bay because you want to see if its the same as the pictures as this other guy maybe.
what is this all about ?
why am i having to defend myself over nothing i have no control over, im not going to own up to something i havent done or to someone you think i am, who cares, id just like to look and post like everyone else without people coming out of the walls at me being childish, savy ?
u seem to no alot about this other guy ?? i havent even seen pics of his car so how can i see if there the same , it makes no difference to me, u ask question about cams and u will better off getting a new cam , like a newman with solid lifts and a new set of springs , cant see why your gettin so upset lol
can we just drop it, im boired with this now.
here is what you are talking about, also you know more than me, its not me bringing it up its you and 2 others in this thread.
https://passionford.com/forum/members/35637-rmwln.html
if your genuinly helping me then thankyou, but i will say my cam cant be worn, its not made of butter, its hardly been driven as its not ready yet for the road.
i would check it, also if u dont no what kent it is how do no its up to the job u need , i swapped my piper t2 for custom speced newman and with the newman i was still makin power at 7.3k, my piper wasnt worn just couldnt do wat i wanted it to do
id much prefere these replies than the ones i been getting.
My piper is stamped too! Just remove distributor and have a look!
Mo is now posting on the S2 section of the RSOC. . . Giving him the benefit of the doubt so far!
