metering unit
Old 11-01-2012, 05:25 AM
Turbo Al
Turbo Al's Avatar
Default metering unit
Got the fiesta running, its a xr2 and ive just done a mi turbo conversion on it. its very up and down missing and clearing. Its new plugs, leads cap and arm so thinking fuel
Am i right in saying if i unplug 1 or both the plugs on the meter unit the car should cut out?
It doesnt, it keeps running the same
Any ideas?
Old 11-01-2012, 10:53 AM
mk1trb
Boost Junkie
mk1trb's Avatar
could be the metering unit, have you got a acumelator(spelling?) fitted?
Old 11-01-2012, 06:44 PM
jan247uk
SE500 All Blue
jan247uk's Avatar
if i read this right you have done a MFI conversion on your fiesta? if so what fuel pump are you using if its an intank pump it will not have enough delivery pressure you need around 5-7 bar for MFI
Old 11-01-2012, 07:13 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Good call above!
If not it might just need the fuelling set up, could of course be a dead metering unit too.
Old 11-01-2012, 07:22 PM
Turbo Al
Turbo Al's Avatar
i have fitted the accumulator and it has a external fuel pump fitted.
im sure with my last rs turbo i pulled a plug off the mter unit it cut out, does anyone want to try it for me on their escort please?
only other thing ive noticed is the auxillery air device that bolts under the inlet manifold, mine doesnt have a sensor on it but ive a white plug sitting there. ive seen a pic somewhere of a white sensor fitted to one?
as far as being set up, ive set the dizzy timing and after that i checked the emissions and it was pretty good to
on the fueling side, the miss seams to clear at mid range and full boost which to me would indicate its getting good fuel pressure?
Old 12-01-2012, 12:09 AM
jan247uk
SE500 All Blue
jan247uk's Avatar
which plug on the metering unit?
i would think auxillery air device should have a sensor fitted to tell it when to operate unless thiers different types i don't know about
Old 12-01-2012, 09:08 AM
Turbo Al
Turbo Al's Avatar
I unplugged both plugs seperatly and both together and it still ran
Old 12-01-2012, 12:15 PM
Karlos G
Balls Deep!
Karlos G's Avatar
The AAD has a in built bi-metal strip and heater coil so adjusts itself as the engine warms up, no external sensor.
Old 13-01-2012, 08:52 PM
Turbo Al
Turbo Al's Avatar
Right i heard all about black and grey plugs, well the loom was grey and unit black so i buggered about and fitted my spare unit with grey plug and still nothin!
Fuel goin in and returning to tank just not distributing?? What makes it distribute? The fuel ecu?
Ill try my spare tomorrow
Old 14-01-2012, 01:27 AM
jan247uk
SE500 All Blue
jan247uk's Avatar
may also need setting up or tuning properly could be the mixture not set right
Old 14-01-2012, 05:43 AM
Turbo Al
Turbo Al's Avatar
when it was running i had it on the emissions tester at work and they were pretty good, a bit rich but ive changed the meter head.
i dont think the emissions would stop the fuel coming throo the unit?
Old 14-01-2012, 09:52 PM
Turbo Al
Turbo Al's Avatar
Recon it is the meter unit too. Got it running, 2 man job, one holding flap down and the other winding it over.
I think its overfueling, misses on idle and until boost starts then it clears, in my opinion the fueling is good for boost. Unit must be sticking. Not to sound like a donut, what does the fuel ecu do?
gingeRS
17
02-10-2015 09:42 AM
Steve Escos
01-10-2015 06:57 AM
Shaunc
Escort Range
23-09-2015 06:00 AM
Quick Reply: metering unit
