Megasquirt-boost control question
A while ago I converted my mfi cabrio to cossie management, this was all well and good as I retained the amal valve.
I've since removed the cossie management and nearly sold it all
I'm soon gonna crack on with putting the car back together, and will be running a megasquirt ecu set up.
I would like to know what people do regarding boost control, my turbo has a -31 actuator do I just pipe the comp housing to the actuator or do I need a boost controller? I know karlos runs a fancy ebc.
Cheers in advance
Stu
Cheers in advance
Stu
ive used it in the past on a st170 engine.... never got good results, ran diferently everyday as could never get compensations right and in the end had issues of the injector driver opening the injectors full on cranking.....
so binned it and never looked back. use DTA all the time now. easy to use too for the self/home mappers
you can download it for free i think from DTAfast website,
quick over view of the cheaper s40...
S40 PROOverview Maintaining the highest manufacturing quality and reliability of more sophisticated ECUs in the S series range it provides a lower priced solution for a wide range of applications.
The primary aim of the S40 is to provide an economic ECU for relatively simple wasted spark four cylinder engines using semi-sequential injection.
Advanced features and system flexibility, however, are in no way sacrificed to this aim.
S40 PRO is also available in an ignition only version ECU Functions
Engine Configuration
20,000 rpm capability
Flexible and easily adapted to different OEM, crank, cam sensor arrangements.
Genuine four and two stroke support.
Twin injector engines.
Semi - sequential injection.
wasted spark or distributor.
User controlled fan activation.
Sensors can be calibrated individually with a lot of preset options supplied.
Flexible Tacho Output
soft and hard rev limits
Main Fuel and Ignition Functions
Comprehensive start up fuelling options both time and temperature dependant.
Air, coolant and manifold pressure compensation maps.
Throttle transient increase compensation.
Throttle transient reduction compensation.
RPM and load breakpoints can be calibrated by the user.
Throttle or MAP as load.
All maps with one or two dimensional with interpolation as required.
Lambda control functions
Extensive lambda parameters table to ensure stable closed loop operation and emissions requirements can be met where needed.
Full three dimensional lambda target map.
Auto-tuning function.
Turbo Control Functions
Open or closed loop turbo pressure control via PWM valve.
Modify target turbo pressure by gear selected.
Modify target turbo pressure by vehicle speed.
Active base PWM map for easy calibration.
Idle Control Functions
Open or closed loop idle speed control via PWM valve.
Closed loop idle target speed temperature dependant.
Fuel enrichment table calibrated versus PWM percentage.
Flexible Input/Output
Three uncommitted input tables which use 0 5 volt inputs or any input the S60 knows already, linked to fuel and advance modifiers and a PWM output.
Launch Control
Fully flexible first gear launch capability.
Extensively tunable to individual vehicles.
Full Throttle Gear Shift Cut
Shift cut capability with 1ms resolution, variable for each gear with
full switch de-bounce capability.
Voltage Compensation Tables
User configurable voltage compensation tables for injector dead time
and coil on time (dwell time).
Diagnostics and Test Features.
Full sensor diagnostics and fault recording.
Extensive engine run time recording at different load and speed conditions.
Ability to exercise injectors and coils without engine running for fault finding.
Other Features
Sealed Latching Connectors
Size 115 x 100 x 41 mm
Weight 268 gm
All outputs protected against over temperature and over current
Inputs protected against severe wiring mistakes and accidents
Reverse battery protection
Alternator load dump protection
Input and Output Features
Inputs
Crank Shaft (Magnetic Only)
Throttle Position
Coolant Temperature
Air Temperature
Manifold / Barometric Pressure
Lambda
Oil Pressure
Fuel Pressure
Oil Temperature
Battery Volts
3 x User Defined Analogue (Shared Use)
Launch Switch
Shift Cut
Undriven Wheel Speed
Outputs
2 x Coil Drivers
2 x Injector Drivers
Tacho
Fuel Pump Relay
Fan/Aux 2/Turbo Pressure Valve (Shared Use)
Idle Valve (Shared Second Injector Driver)
Shift Light
I've mapped a few DTA's it's ok but nowhere near MS. It's better than say Gotech but you still map in terms of pulse width for the main fuel table.
Rick
Rick
I've run MS for around a year now. With some intelligent mapping (ie, read the manuals properly and think about things before pressing buttons) you get very good results. My AFR is spot on now in all conditions, and it delivers power very smoothly with decent throttle response.
Im not saying DTA is shite, but its far from being better than MS.
Studabear, have you considered using megasquirt to control your boost via a solenoid valve? MS2 will do open and closed loop boost control. I will be testing this function over the next few months.
Rob,
Rob,
If you had issues with the injector drivers im really not surprised it ran differently day to day.
Rob,
Rob,
I've got a big shopping list at the minute.
http://www.ebay.co.uk/itm/PERRIN-UPR...item3f026fcd36
As above, the perrin will work, as will several others, http://www.ebay.co.uk/itm/AEM-Turbosmart-boost-controller-solenoid-control-valve-/110794290646?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item19cbdab5d6
or cheaper but the same i think.... http://www.ebay.co.uk/itm/Gizzmo-IBC...item336fa329a1
The ecu mod is pretty straight forward too, transistor (tip121 will work well here), protection diode and a resistor, you may or maynot need a pull up resistor too. Similar to the idle circuit. Some ecus come with this as standard so check when you buy.
Rob,
Rob,
Closed loop idle is very dependant upon the settings used for the pid algorithm, open loop pwm is very repeatable and stable, I've had an ecu on the bench working for over 14 hours now with idle valve, injectors and coil attached testing for reliability, with a scope attached and the pwm % hasn't drifted at all.
I'd be comfortable with open loop boost control but i haven't tested the closed loop at all but i suspect it will be the same as closed loop idle. But like you say a separate and dedicated boost controller would be the best all round solution.
Im using a gizzmo at the moment which works really well, but i have read really good reviews for a few controllers now, theres a back to back magazine test article somewhere which really sorts the good from bad, ill see if i can find it.
Rob,
Heres an alright write up for the mod on an MS1, MS2 does the CL much better from what i understand,
http://forums.turbobricks.com/showthread.php?t=80599
There are a few people using the CL here with a good write up
http://www.e30tech.com/forum/showthread.php?t=30543
For the money it will cost you i would be tempted to give it a go, but if you want something which works right out the box i would just get a proper boost controller like a gizzmo or avc-r (which i believe karlos highly rates).
Rob,
Rob,
*** Sierra RS Custard ***
IME anyone slagging off megasquirt just simply doesnt understand enough about mapping to realise why its good to have so much functionality.
Agreed, the DTA still very much feels like an older generation of ECU to me, its a step forward from the older P8 Pro etc but its still nowhere near the modern stuff like autronic and megasquirt etc where you have proper normalisation of the data in terms of seperation between VE map and injector scaling etc.
Does anybody have a contact email for the fella who runs extra efi.
The contact section on his site keeps sending me to either a Gmail page or a yahoo mail page.
I haven't got a ecu yet rob, I was just gonna try and get a quote from them.
edit to add, as I'm now near on in the position that I will need to get 1 on order in the next couple of weeks.
Speak to karlos first. He did mention a while back he could get good price's lol
Balls Deep!
philip.extraefi@ntlworld.com
I've spoken to rob regarding this, but at this time I may have to use extra efi inorder to get the car running in the next couple of months.
