lsd testing
Old Oct 15, 2011 | 11:48 AM
boost monster's Avatar
boost monster
Default lsd testing
I have my car on axle stands in readyness to repair the slipping clutch, I started it up put it in first gear on idle and was able to stop any one of the front wheels. Should I be able too? I know there is a test in the Ford manual where one wheel is place on the mot brake rollers and the car has to pull its self out in a certain time but it's to late for me to try that now.
Old Oct 15, 2011 | 05:18 PM
zippyobrien's Avatar
zippyobrien
I'd say that means u have a xr3i box.
Wen you pull the shafts out , if it looks like there's a horizontal pin in there then it's not a LSD
Old Oct 15, 2011 | 05:39 PM
studabear's Avatar
studabear
Thats what I found a couple of weeks ago
Old Oct 15, 2011 | 05:43 PM
boost monster
I definately have a lsd box my problem is, is it working or do you have to be alot more aggressive with the revs for it to lock. It has left 2 black lines in the past but it done a fair few miles now.
Old Oct 18, 2011 | 10:12 AM
Rogeyboy's Avatar
Rogeyboy
Hit a tight corner hard in 2nd, roundabout etc and see if 1 wheel spins (the inside wheel) or it grips and pulls you round the corner, if its good you can feel it pulling the wheel into the corner...
Altho if your running good power you could just spin both front wheels and end up with no steering and have to lift out of it...
All good fun tho - enjoy!
Old Oct 18, 2011 | 12:39 PM
martysmartie's Avatar
martysmartie
Far easier and safer than any of the above, merely turn one driven wheel by hand (Out of gear obviously), if the opposing sides wheel spins the opposite way you have an open diff, it it turns the same direction you have a LSD!
Martin
Old Oct 18, 2011 | 12:54 PM
2ndGear's Avatar
2ndGear
it sounds like the resistance in the led unit itself is worn. You get get them pumped up to be better than standard
Old Oct 18, 2011 | 02:21 PM
N.Saph's Avatar
N.Saph
New Ford sierra owner
Martin
i agree with the above
an to test how tight the diff is, im sure you dot need any advise there lol
but very cheap to get tightened an shims put in place to make them lock when you wanna have some fun
Old Oct 18, 2011 | 04:23 PM
Rogeyboy's Avatar
Rogeyboy
My lsd clunks when i reverse and turn, is this a common problem with them...?
Worn internally maybe?
Old Oct 18, 2011 | 04:36 PM
N.Saph's Avatar
N.Saph
i get the same, only its not my lsd, its somethin in the front clunks when i turn an reverse with full lock?
Old Oct 18, 2011 | 05:06 PM
boost monster
As the gearbox need to be stripped to repair oil leaks, who can recondition the lsd?
TPM961
Jan 15, 2018 10:50 AM
tankybaby66
Feb 6, 2016 02:24 PM
mk1turboestate
Dec 2, 2015 08:31 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
