cps sensor
Old Oct 14, 2011 | 06:15 PM
michaelward's Avatar
michaelward
Default cps sensor
i am doing a efi conversion and i was just wondering if anybody has got any pics of the cps sensor also i have got the hole in the block but do i have to have any brackets or anythink cheers
Old Oct 14, 2011 | 06:52 PM
Rogeyboy's Avatar
Rogeyboy
There is a bracket/holder than bolts into the block from the gearbox side, also there is 2 types of sensor as i found out doing my turbo conversion... An Xr2i or Xr3i CPS is longer than a fiesta turbo one, and the holder matches the sensor.
If the holder sticks out of the block around 25mm/1inch then you need the longer sensor, if the holder sits 5-10mm out then the shorter sensor in required IIRC...
Hope that helps!
Old Oct 15, 2011 | 12:03 AM
michaelward
I fink I have got a fiesta Rs cps but haven't got the holder/bracket do you no where I can get the holder from cheers
Old Oct 15, 2011 | 10:44 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
What do you need picture of TPS for?
I have EFi escort so can get a picture easy enough, it's non turbo but same setup.
Old Oct 18, 2011 | 11:01 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Its ok having the cps sensor and bracket and even the hole in the block. But do you have a flywheel to work with it.
Old Oct 18, 2011 | 10:10 PM
Rob_DOHC's Avatar
Rob_DOHC
Hi mate, ive got a holder somewhere i can take a few pics of if you like, and a part number.
You can still buy them from ford, mine was a fiver.
The holder needs to be fitted to the block before you fit the gear box iirc. As Jano says you need the efi flywheel too
Got plenty of pics kicking about of random efi stuff just ask mate.
Rob,
Old Oct 19, 2011 | 05:47 AM
tasos77's Avatar
tasos77
rs turbo from Greece...
Rob,
You saved me.... i'm going to change my clutch and then i will go to efi, but i didn't know this...
Old Oct 19, 2011 | 06:30 AM
gus's Avatar
gus
this is my ew cps ....
and my old one ....
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
