Using Water
Old Sep 27, 2011 | 06:55 AM
Mids_s2's Avatar
Mids_s2
Default Using Water
Hi my rst turbo has started using water but theres no obvious leaks,its not lost any power and the oil and water dont seem to be mixing any ideas?
The engine in a power engineering 1900 with a stage 3 head could it be the head gasket or something else eg the block??
Thanks Ben
Old Sep 27, 2011 | 07:14 PM
rsturbo1's Avatar
rsturbo1
i had the same problem mate it ended up being the gasket between the block and fuel rail, apparently there prone to going on number 2 cylinder which has something to do with water.
Old Sep 28, 2011 | 12:35 PM
Mids_s2's Avatar
Mids_s2
Hi which gasket do you mean mate? Head gasket?
Old Sep 28, 2011 | 12:39 PM
rsturbo1's Avatar
rsturbo1
inlet manifold gasket
Old Sep 28, 2011 | 02:22 PM
Mids_s2's Avatar
Mids_s2
Ok cheers will research that.
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
