Gearbox Question
Old Jun 20, 2011 | 10:25 AM
Mids_s2's Avatar
Mids_s2
Default Gearbox Question
Hi is there any way i can strenthen the BC box so it can take alot more power/torque without doin the conversion to a different box?
cheers
Old Jun 20, 2011 | 11:20 AM
stuart collins's Avatar
stuart collins
no , it will strip the gears
Old Jun 20, 2011 | 12:53 PM
luke19790_3's Avatar
luke19790_3
use can use mk6 escort diesel box, little bit better.
Old Jun 20, 2011 | 01:58 PM
Mids_s2's Avatar
Mids_s2
what power will the diesel box take?
Old Jun 20, 2011 | 01:59 PM
chaffe's Avatar
chaffe
Turbocharging Technician
diesel box is the same lads, diferent ratios thats all
Old Jun 20, 2011 | 02:34 PM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
No they are not at all
Old Jun 20, 2011 | 02:59 PM
mattseries2's Avatar
mattseries2
Best bet fit a MTX
Old Jun 20, 2011 | 03:23 PM
chaffe's Avatar
chaffe
cheers
If this could be done effectivly then ford would of done it and there would be no need for a stronger box like the mtx75, getrag 6 speed, or the volvo one in the focus rs/st
Old Jun 20, 2011 | 04:37 PM
luke19790_3
its a ib5, i could be wrong?
Old Jun 20, 2011 | 05:35 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes it's an IB5 and yes they are a bit stronger, not massively so but better than nothing.
Diesel or not is irrelevant, any IB5 will be an improvement over the BC.
Old Jun 20, 2011 | 08:27 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
You can buy 6 speed IB5 boxes with different gears and LSD etc. costly.. which is why the MTX75 is the best value for money gearbox option.
Old Jul 25, 2011 | 03:31 PM
Dennis_Wiseman's Avatar
Dennis_Wiseman
What sort of power and torque level is loosely regarded as ''safe'' with a ib5 plus diff before you need to be looking at changing up to a MTX75 ?
Can a ib5 happily run say 250 - 270bhp ?
Old Jul 25, 2011 | 03:37 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Christian ran 350bhp through an IB5 and it was fairly reliable, he also fitted a drain plug so the oil could be changed regularly and easily.
I've been running 240bhp through one for the last year and not broken it, this is after breaking four BC box's.
Old Jul 25, 2011 | 03:47 PM
2ndGear's Avatar
2ndGear
get a shot peened cryo box, £1200 with an ATB fitted
Old Jul 25, 2011 | 03:54 PM
Sjieter's Avatar
Sjieter
What power can the standard box handle? i hope 160-180 ? else i have to look for another one ..
Old Jul 25, 2011 | 04:03 PM
XR2's Avatar
XR2
Standard BC box was built for ~190 Nm torque
Standard IB box was built for ~195 Nm torque
There are rumours about diesel boxes being stronger, but I've not seen any proof yet... well some diesels had MTX boxes fitted. They're built for more torque than the BC/IB5 boxes.
A friend of mine usually broke two gearboxes with his S1 (1850 CVH, WM management, T34) during one summer season.
Old Jul 25, 2011 | 04:15 PM
stuart collins
why???, when i asked they said its only rated to 300bhp and couldnt take what i want to but through it
Old Jul 25, 2011 | 04:18 PM
stuart collins
ive run 330bhp through a standard box then changed to a uprated 1 which let go , its luck of the draw some will take it, some will let go at 200bhp
Old Jul 25, 2011 | 05:29 PM
Dennis_Wiseman
Was the standard box a diesel ib5 one or petrol and did you have it rebuilt with new standard internals prior to fitting? Cheers
Maximum power i want to run is 300 and the car for mainly road use which the boost would be turned down for and the odd quarter mile when it would be whacked up haha
Old Jul 25, 2011 | 05:39 PM
stuart collins
rs turbo bc standard rebuilt box, up to u but a rebuilt rs turbo box with diff is goin to be 1200-1400 dependind on which diff , my last 1 with gripper last 5miles , i would but that money 2wards a mtx conversion theres abox in the for sale room
Old Jul 25, 2011 | 06:00 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Speaking of diffs running an ATB will break your box easier IMO, it's a very harsh diff, I now run a Racing Puma Viscous LSD which is much 'smoother' although it doesn't give quite as much grip as my old ATB it's a good compromise.
Old Jul 25, 2011 | 09:48 PM
boost monster's Avatar
boost monster
How do you tell the difference between the B5 and the IB5? Can the standard LSD be reconditioned?
Old Jul 25, 2011 | 09:54 PM
Karlos G's Avatar
Karlos G
Balls Deep!
IB5 has more webbing on the casing to prevent flex, it also has a core plug behind the main shaft bearing that can be seen when out the car.
Yes the RST LSD can be reconditioned.
Old Jul 25, 2011 | 09:57 PM
XR2's Avatar
XR2
where? who?
A friend of mine opened his to see what's inside and can't put it back together now
Old Jul 26, 2011 | 03:42 PM
boost monster
Is this an IB5
Old Jul 26, 2011 | 04:08 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Originally Posted by XR2
where? who?
CTS mate.
Originally Posted by boost monster
Is this an IB5
No.
Old Jul 26, 2011 | 04:13 PM
boost monster
Bugger
Old Jul 26, 2011 | 09:55 PM
series_one_rst's Avatar
series_one_rst
I got a six speed box to do the conversion in knowing to me the rest of it costs an arm an a leg. bummer! might just go for mtx??
Old Jul 26, 2011 | 10:55 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
i converted my mk2 fiesta zetec turbo to run a mk1 focus rs gearbox.
what it cost me (sort of i broke a mk1 focus so got the box cheep)
box expect to pay £600
shafts £200 a set (you can use different shafts but i used the rs ones)
lincage £50
hydro clutch conversion and gearbox mount £140
clutch and flywheel (second hand £150 if your lucky)
i had to space my engine forward 15mm. I cut the inner chassie leg to make room for the box had to make a back mount i used the standard mount and worked from there.
as for the shafts i had some sleves made up (if any one wants some made, same as the mount and clutch conversion i can point you in the right direction) so that i could slot a mk2 xr2 shaft in one end and a focus rs shaft in the other cut them to the right lenth then welded them.
i ran the shafts at 15psi (260hp) but have now sent them off to be made into one piece shafts
Old May 1, 2015 | 08:33 PM
zetecbeast's Avatar
zetecbeast
Under the car...!
How can I tell the difference between an IB5 and an MTX??
This is mine. I was told it was an escort diesel box. From my research Im hoping it is an MTX???
It is hydraulic clutch, and operated by a shifter linkage.
cheers
Old May 1, 2015 | 09:08 PM
luke19790_3
Do you have any better pictures?
The mtx has the rod linkage to the left where the ib5 is on the right
Old May 1, 2015 | 10:52 PM
zetecbeast's Avatar
zetecbeast
Under the car...!
Sorry mate, pictures are indeed gash!
Heres a couple more, looks like the rod linkage is on the RHS...?
The box will be coming out on monday but Im trying to prepare for the worst ££.....!!!
Old May 2, 2015 | 09:20 AM
luke19790_3
This a mtx from rs2000
Old May 2, 2015 | 10:11 AM
zetecbeast's Avatar
zetecbeast
Under the car...!
THanks, Have you got one from the other side??
Old May 2, 2015 | 02:34 PM
luke19790_3
I have a rs2000 box in mine fitted with frs lsd
Old May 2, 2015 | 05:04 PM
zetecbeast's Avatar
zetecbeast
Under the car...!
Thanks mate. How easy was it to fit the FRS LSD? what did you have to change? driveshafts? I am going to compare mine very closely to this photo later tonight if I can get it out, which I am planning to do shortly
Old May 2, 2015 | 05:05 PM
zetecbeast's Avatar
zetecbeast
Under the car...!
It looks very very much like mine this does, it gives me big hope mines an MTX!!! Will know shortly
Old May 4, 2015 | 02:19 PM
zetecbeast's Avatar
zetecbeast
Under the car...!
Right, I've got it all out today. It's an MTX, looks identical to yours mate
Ignore the large steel bracket on the left of the pic (its for clutch slave cylinder mounting)
and also the rod linkage shown on the other picture. I will be reusing that for the new box.
SO, what are my options? If I have a focus RS box, can I swap the internals out and put them in this? Are the gears shotpeened in the RS focus box? is the LSD and easy swap into this case?
If I use current case then I could use current speedo etc? thanks
Old May 5, 2015 | 12:43 PM
zetecbeast's Avatar
zetecbeast
Under the car...!
As an update to this. I am buying an RS focus box.
I am hoping the ratios will be good, I am guessing they will...
I have no idea how I will get the speedo working, I also am hoping I can use my shifter rod linkage mechanism as the cable setup will be a right pain to customise for a non Ford FWD car I think...
Anyone?
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
