boost problem.. confused
Old Apr 2, 2011 | 12:03 AM
ajh_91's Avatar
ajh_91
Default boost problem.. confused
foot to the floor soon as i hit full boost on my car which is 1 bar peaks at 1.5 bar.. i sometimes get like a limiter feeling sounds like burbling.. yet other times it will accelarte just fine no promblems.. sometimes it will burble for a second then accelarate then burble... its and intermitant problem.. any surgestions ?
Old Apr 2, 2011 | 12:12 AM
mk3matt's Avatar
mk3matt
sticky actuator.... u runing an eleccy boost control? check solenoid aint stiking
Old Apr 2, 2011 | 06:35 AM
essexRSTSouthend's Avatar
essexRSTSouthend
1.5 bar aint a bar of boost.just under 15psi is a bar.so if that the case your running way too much boost? If your motor set at a bar,then it should hold about 13psi.
Old Apr 2, 2011 | 06:51 AM
essexRSTSouthend
Just to let you know,if your running 1.5bar at peak,thats nearly 22psi.
Old Apr 2, 2011 | 07:54 AM
Rogeyboy's Avatar
Rogeyboy
Its boost cutting when it hits 1.5bar would be my guess, check for air leaks in the pipework to the actuator and that the actuator is opening the wastegate...
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Mark RS
Oct 12, 2015 06:01 AM
locum8
Oct 1, 2015 01:50 PM
Russ Payne
Sep 25, 2015 08:29 PM
