Electrical prob! Battery
Guys randomly my head unit stereo cuts off n bk on again n battery light cones on, then off while driving or whens car running! Battery earth if it has one?
Ok guys it happened agen today twice! Defo to do wiv battery sumwer. Connection or sumtn cos when i started the car in morning it was showimg battwry dead but after a few trys it started so im lookng into a
Bad earth to batter?
Alternator earth?
Battery itself!
Alternator earth?
Battery itself!
As I say do you have a sub? If it were alternator then you would have noticed it by now and it woulden't make the stereo cut out, however if you do have a sub etc these can pull alot of power, maybe demanding more current then the alternator can supply hence illuminating the no charge warning lamp, earths are good idea to check as well as they are more than likely corroded and a clean won't be no harm!
Martin
Martin
Martin no mate i dnt av a sub, basically my alarm wudnt activate earlier., no power was goin to car at all but after a few tries it started agen with no prob, so its a power issue from battery! Defo alternator or earth prob!
Fresh onion..
From what you have said it sounds to me like its the battery terminal loose or the ignition switch multiplug is loose/poor connection, I would check these first, especially the ignition switch multiplug, its is a large black plug under the steering column, just take the shroud off and you will see it, give it a tap and a wobble when trying to start it when you have no power
check the battery connections mate, mine was doing this and missfiring when going over bumpy roads after i fitted a new battery. It turned out one of the connections had worked its way loose, once all tightened up its running 100% and starts first pop with no hesitation.
After all this it finally broke down on me lol jus cut out n no power was going to the car at all! got it toed home to find out it was actually bad earth to battery! Done a battwry test n it was fully charged!We used a jump lead to earth it n it started so now i just need to check all battery connections n earth points!
Can soneobe pls tell me all the earth points on da car pls from battery!
Loads simply impossible to list all of them, since every item has an earth, some use common earth points, others there own, to be honest it's usually the earth point thats the problem, due to the age and the inherent problem with rot/corrosion, the wiring not helping either due to age, I would just visually inspect all the underbonnet connections as these are the ones that are exposed!
The engine earth strap is also an often overlooked but important connection!
Martin
Martin
07-10-2015 12:56 PM
