I know some will say im sad but....
I want the dump valve on my s2 Rs turbo to be as loud as possible . I currently have a forge fast-road item, which i believe is a group 'a' or summat (or did i just make that up-im not sure) but its not quite as loud as the bailey i had on my old rst. If anyone would like to swap my one for a baileys then let me know, also will it be louder if i take off the foam filter? Or will it ruin it? P.s Padvg or whatever i know your views so don't have a go at me!!
How much boost are you running obviously the more boost your running the louder your dump valve will sound. I have a bailey DV26 twin piston dump valve and it sounds the buisness. I notice since i had my car chipped the dump valve sounds much louder. going from 7-9 p.s.i up to 17 p.s.i what a big difference it made
Why do you think dump valves are . Are they just sales gimmicks because i thought a dump valve makes your turbo last longer because with out one you get back pressure on the bearing or as its called (compressor stall)and they also help with lag and also sound nice. I suppose everyone has their own opinion
They dont make it last any longer bottom line is they run better without dump valves on majority of cars is just to get noticed and serve no purpose , dont get me wrong some of the BIG booster cossies/rst`s may be better off with one
have tried my car loads now with dv on and off and cant notice any improovement in running so its defo getting left on!
But on my Turbo there is a massive difference
Strange one...?
Strange one...?
Can someone tell me in what way does your motor run better with out the dump valve does it idle better and run more smooth.So if i was to take my dump valve off will i get the chatter sound let us know.Im running 17psi
i bought a twin piston forge motorsport item when my car was running standard boost (7 psi) and it wasnt enough to actually force the piston back and dump one off.
I took it back to larkspeed and swapped it for another, this time it was there but only just. Sounds a lot better at 15+ psi
I had a DV on my old one for 3 months out of the 6 i had it, i took it off aweek before i sold it and wished so much that i hadnt put it on. Drives soooooo much better without oneon!!!!
Each one ot their own though!!
TC-ST3
26-09-2015 04:47 PM
lockie
31-07-2015 10:03 PM
