in line restrictor, where from??
Old 10-02-2011, 12:01 PM
kermitt
kermitt's Avatar
Default in line restrictor, where from??
Trying to find one of these cos my boost gauge flickers and rattles.
http://store.42draftdesigns.com/Inli...ctor_p_99.html
Have tried to order this from the site but only seems to let you if you are a US customer.
Old 10-02-2011, 12:33 PM
bezo
powered by K26
bezo's Avatar
what boost gauge are you using?
Old 10-02-2011, 12:41 PM
chaffe
Turbocharging Technician
chaffe's Avatar
the best by far, ive done it several times with brilliant success is a twisted bit of wire wool (not much, only 1" long) poked down the pipe, close to the gauge. Try it, it stops flickering, and the gauge is still very quick and responsive
Old 10-02-2011, 12:58 PM
kermitt
kermitt's Avatar
Some cheap kack from ebay that works ok but the constant ticking its driving me nuts. I asked for one with a psi readout and got sent one with bar readout but at least I know its boosting lol.
Old 10-02-2011, 01:34 PM
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
put some oil in the pipe, might help.
Old 10-02-2011, 04:19 PM
Rob_DOHC
Rob_DOHC's Avatar
lol, just get a decent gauge. They aren't that expensive!
Old 10-02-2011, 07:07 PM
bezo
powered by K26
bezo's Avatar
2nd that!
Autometer always come out top on tests and arnt that expensive.
cheap ebay shit/ripoffs arnt worth buying as you end up buying things twice
Old 11-02-2011, 05:55 AM
chaffe
chaffe's Avatar
not listening to my cheap, proven solution then
Old 11-02-2011, 09:28 AM
Rob_DOHC
Rob_DOHC's Avatar
Lol relax, im sure he will. But cheap boost gauges give me the right ball ache. They always over read or under read, i had one that gave me a different peak figure every time i came on boost, one min i was running 13psi, the next 20 lol.
Rob,
Old 11-02-2011, 09:33 AM
chaffe
chaffe's Avatar
lol, ive had loads of TIM gauges and similar, they have all been pretty good accuracy wise, some did require "calibrating" to get them to sit on zero right enough. im surethe bourdon tube mechanism is from the same manufacturere in most cases any hoo.
Old 11-02-2011, 02:34 PM
Canada1
Canada1's Avatar
Hi Rob,
Maybe that 200+HP 12 psi 1.6cvh had one of those cheap boost gauges?
Old 11-02-2011, 03:52 PM
essexRSTSouthend
essexRSTSouthend's Avatar
Originally Posted by Canada1
Hi Rob,
Never had one fitted.Reading's from dyno.So dyno fault?
Old 12-02-2011, 12:46 AM
Canada1
Canada1's Avatar
Hello Essex,
Beautiful car!
You don't have a boost gauge?
I would only trust a top end brand of gauge. It certainly sounds like something wasn't quite right at the dyno shop.
Old 12-02-2011, 12:03 PM
Rob_DOHC
Rob_DOHC's Avatar
I agree with that Perry, much better having something you trust, so you can spot a difference really quickly.
Old 12-02-2011, 02:28 PM
essexRSTSouthend
Hello Essex,
Beautiful car!
I've been wanting a boost gauge for long time.Just so many to choose from and as you say having one you can trust does help. Everyone mostly points to autogauge.So might use them?
Thanks for the comment Canada1
Old 12-02-2011, 03:22 PM
Canada1
Canada1's Avatar
I have purchased an Innovate Motorsports vac/boost gauge. Same manufacturer that I purchased the wideband O2 sensor from.
Most companies have cheap ones available, stay away from the lowest costing ones.
Old 12-02-2011, 05:10 PM
essexRSTSouthend
Cheers dude!
Old 12-02-2011, 05:34 PM
Rob_DOHC
Rob_DOHC's Avatar
This is the boost gauge i have just bought,
But as above autogauge seem to work well. I just like the stack gauges.
Old 12-02-2011, 05:57 PM
chaffe
chaffe's Avatar
i tend to use the reading on my laptop from the ecu as the correct boost figure, and double chech that with the gauge
Old 12-02-2011, 08:09 PM
Canada1
Canada1's Avatar
Hello Chaffe,
That is the best way to calibrate a boost gauge - however if the map sensor has been overpresurized they certainly can be out of spec too.
Old 12-02-2011, 08:19 PM
chaffe
chaffe's Avatar
Hello Chaffe,
hi, yeah, but where do you stop lol? if the ecu is dunked under water it may be out of calibration too lol
