220/250bhp???
Old 16-03-2011, 06:23 PM
  #41
gus
gus's Avatar
std cam was quite good so im led to believe
ford must of done their research
Old 16-03-2011, 07:03 PM
  #42
J1mbo
B1mbo
J1mbo's Avatar
Not overly modified, I know exactly what you mean about the poor STD ports, it was very Mildly cleaned, to smooth the casting marks as he was looking for 230bhp
It was on webber l8 ecu mapped by my dad, cracking engine actually
The problem I have with the STD cam is it makes for a engine that peaks very early
Ps remember this is a 310bhp turbo at 25 psi it is just forcing it through, where as my engine with mild port head and cam made 2 more bhp for 3 psi less boost
He was on the std s2 inlet
Old 16-03-2011, 08:44 PM
  #43
Canada1
Canada1's Avatar
Hello J1mbo,
Sounds like a cool project.
Love to see pics of it someday.
Old 16-03-2011, 08:54 PM
  #44
J1mbo
B1mbo
J1mbo's Avatar
Thats not my engine there, mines on pectel t2 as said with ported head and cam etc, just putting steel rods, forged pistons, new inlet and a bigger cam in
I have a build thread on my escort in the rest room have a search if you fancy a look, build from the beginning where she was a STD 1.4 escort!
Old 16-03-2011, 11:25 PM
  #45
Karlos G
Balls Deep!
Karlos G's Avatar
Yeah Christian said the Newmans off the shelf RST cam is a very similair profile to the Ford one, but as Jimbo says it peaks a bit early for big BHP, this of course can be helped by retarding the cam timing a few degree's.
Old 17-03-2011, 12:02 AM
  #46
essexRSTSouthend
essexRSTSouthend's Avatar
Ford cam nearly same as newman....
So i could get aftermarket pully to adjust the standard cam.. intresting
Old 17-03-2011, 04:25 PM
  #47
Karlos G
Balls Deep!
Karlos G's Avatar
No probably not, having similar characteristics does not mean adjusting the cam timing will yield the same results as fitting the Newman.
Old 17-03-2011, 05:22 PM
  #48
Rogeyboy
Rogeyboy's Avatar
What do you guys mean by the cam "peaking too early" making max bhp too early?
What is an ideal cam for making smooth power with minimal lag over the ford item...?
Old 17-03-2011, 05:45 PM
  #49
essexRSTSouthend
Thats not what i ment.but by using a adjustable pully on a standard cam could get few more bhp.
Old 17-03-2011, 06:13 PM
  #50
Karlos G
Balls Deep!
Karlos G's Avatar
Typically a laggy cam will make a higher final BHP on a single cam engine and a resposive cam will make less BHP, it's about where peak flow is.
Ah got ya, yes you can gain a few BHP with a vernier but at the cost of low down response of course.
Old 17-03-2011, 06:46 PM
  #51
essexRSTSouthend
So it would move torque futher up the rev range? Cheers
Old 17-03-2011, 07:50 PM
  #52
Karlos G
Balls Deep!
Karlos G's Avatar
Yes mate.
