lambda sensor fitment
Old Jan 19, 2011 | 03:05 PM
RSandy's Avatar
RSandy
Default lambda sensor fitment
been offered the innovate LC-1 air/fuel ratio monitor from my mate motor cheap, but he doesnt have the lambda sensor for it.
can i use any 5 wire wideband spec lambda sensor? if so, where is best to get hold of 1, and what sort of ballpark figure am i looking at?
also, where is best to locate the sensor itself? if im right, its supposed to be a minimum specified distance from the turbo to avoid it baking to death, so im thinking fit it in the downpipe just behind the sump, so i can run the wiring down the bulkhead. would this be an ok location for an accurate enough reading?
Old Jan 19, 2011 | 03:09 PM
chaffe's Avatar
chaffe
Turbocharging Technician
They use a Bosch sensor (LS1 i think) can be had for around fifty quid from most motor factors/dealers or ebay, you are right about your placement too, it must also not be directly above (gets too hot) or slanting downhill (can fill with water condensate)
Old Jan 19, 2011 | 03:11 PM
chaffe's Avatar
chaffe
sorry its "LSU4" quite common, as said fifty quid
RSandy's Avatar
RSandy
must not be directly above what? and must not be slanting downhill? might just be me getting confused here lol
do u mean weld the boss into the side of the pipe rather than on top?
Old Jan 19, 2011 | 03:16 PM
chaffe's Avatar
chaffe
The lambda sensor must not be directy above or facing downhill for the above reasons, a quick google will show you picks of how to mount it
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
