For anyone interested in custom dash dials/gauges...
Old 14-01-2011 | 05:27 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default For anyone interested in custom dash dials/gauges...
Wanted my speedo, rpm, fuel and water temp to match my boost, oil press and temp so this is what I did...
Cut out old middle section and remove all the unwanted back bits, I've retained the warning lights at the top..
Cut perspex to size/shape and spray satin black..
Fit new dials to perspex and screw to original surround..
Sort wiring, I did it this way to use the RST loom plugs in case I ever need to use stock dials again..
Fit to car and enjoy!
I'll get some pics in the daylight tomorrow!
Old 14-01-2011 | 05:36 PM
little bram's Avatar
little bram
the wires look like a fuck on or is it just the pic. i like them tho they look good
lee
Old 14-01-2011 | 05:37 PM
gus's Avatar
gus
looks awesome
the illumination looks sweet
was you on the phone or something when cutting the holes in the perspex?
or your compass broke
Old 14-01-2011 | 05:41 PM
stevealien's Avatar
stevealien
good work there karlos.
Looks sweet buddy .
prob gonna do mine eventually
Old 14-01-2011 | 05:52 PM
syko2005's Avatar
syko2005
burning oil
looks mint that does mate
Old 14-01-2011 | 06:07 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Cheers fella's!
lee
They are soldered to the original circuit membrane, insulated with tape and left full length just wrapped up so if I ever need to return anything to normal I can and if I ever need more length on the wires there's plenty there, does look a mess though!
Originally Posted by gus
looks awesome
Jigsaw in one hand, perspex in the other, not easy! lol
Old 14-01-2011 | 06:42 PM
james kiely's Avatar
james kiely
nice one karlos ,looks great
Old 14-01-2011 | 06:49 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
Very nice, bud
Old 14-01-2011 | 06:58 PM
burnhamshaun's Avatar
burnhamshaun
They look wkd mate how have you calibrated them or are they just a straight fit plug and play how does rev counter work would love a set like this
Rsmat's Avatar
Rsmat
300+
looking good.
Old 14-01-2011 | 07:00 PM
Gav Diamond's Avatar
Gav Diamond
Lol
Finished result looks great though bud
Old 14-01-2011 | 07:11 PM
PETEDUDE007's Avatar
PETEDUDE007
that looks really tidy in the dark!
Old 14-01-2011 | 07:20 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Rev counter works off either your coil or if your EFI the ECU, MPH is calibrated over a predetermined two mile drive or in my case a drive whilst waiting for the GPS counter to hit two miles, fuel gauge has 10 presets for various fuel senders and temp gauge has it's own sender that fits direct in place of the stock RST one.
Old 14-01-2011 | 08:45 PM
muz's Avatar
muz
Wye Valley Hardcore
Very nice, Karl. I want to replace mine with Stack stuff so I've got more accurate water temp and speedo etc, but for it to look OEM. Tha'ts a good little guide.
Old 14-01-2011 | 08:52 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Cheers Muz!
Yeah I wanted a sort of OEM look, tidy if you know what I mean and not stuck on.
Old 14-01-2011 | 09:59 PM
morph's Avatar
morph
That is really good! looks spot on, not too over the top and actually works!
Old 14-01-2011 | 11:07 PM
RichieST's Avatar
RichieST
Crikey, 10,000 rpm is a little optimistic eh
Nice job by the way
Old 15-01-2011 | 10:01 AM
Karlos G's Avatar
Karlos G
Balls Deep!
10k all the way mate! ............... lol
Old 15-01-2011 | 10:16 AM
dave_s2_rst's Avatar
dave_s2_rst
look spot on fella, and nice one for posting up how you did it.
Old 15-01-2011 | 10:26 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Couple of daytime shots...
I'm thinking about losing the glass (well plastic), because the dials are quite bright they show up all the scratches (never seen them before) at night and compared to the other three dials they look noticeably duller and a little blurry, cant see it in the photo's and it's probably only me that picks up on it (being quite critical) but I will have a play and see.
Old 15-01-2011 | 01:13 PM
jessie_rs's Avatar
jessie_rs
laid out nicely but not a fan of the range of gauges
Old 15-01-2011 | 02:28 PM
Rogeyboy's Avatar
Rogeyboy
Karlos loving the gauges m8... Also not seen the centre pod before, i'd like something similar for my gauges - top work!
Also once fitted it looks nice and tidy, who cares what the holes etc are cut like and wiring looks like - you don't see em with gauges fitted! Really nice touch on an OEM+ look i think.
How did you wire in the "dimmer" function down by the drivers air vent?
Old 15-01-2011 | 03:12 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Cheers dude!
Centre pod is a one off done by Twins on here.
Yeah exactly, the bezels cover the edge of the holes which is why I wasn't arsed about a perfect circle, the wiring is a mess but it's all soldered so no bodges! lol
The dimmer works as normal because the dials are wired into the stock loom, although it doesn't dim quite as much as before
Old 15-01-2011 | 03:22 PM
bencossie's Avatar
bencossie
so karlos how much you charging to make them lol good work looks fab
Old 15-01-2011 | 03:48 PM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
they do look good karlos
but got to ask what the 2 smaller holes are for ??
Old 15-01-2011 | 04:10 PM
Korda's Avatar
Korda
would look alot better without plastic imo, nice to see matching gauges mine are all odd
Old 15-01-2011 | 04:19 PM
burnhamshaun
guessing its the indicator lights mate
Old 15-01-2011 | 04:25 PM
caprigirl21's Avatar
caprigirl21
that looks awsome where can i get them style gauges ????
Old 15-01-2011 | 04:32 PM
Karlos G's Avatar
Karlos G
Balls Deep!
lol
Indicators mate.
Yeah I'm undecided, going to run for a week with it in then take it out and see what I think.
Spot on.
www.autometer.com
Old 16-01-2011 | 12:21 AM
Puss2's Avatar
Puss2
Formerly know as Puss
Looks good
I left the plastic off when i got my stack gauges as it looked better
Old 16-01-2011 | 07:45 PM
makaveli96's Avatar
makaveli96
Looks good Karlos I like that.
Old 17-01-2011 | 08:39 AM
looking good
Old 17-01-2011 | 09:35 AM
muz's Avatar
muz
Wye Valley Hardcore
Can you not polish the plastic up to take the scratches out? Or is the plastic a little soft and would just make it worse?
Old 17-01-2011 | 11:00 AM
javierant3's Avatar
javierant3
Looks sweet!! lol I would save some pics in my computer. I want to do something like that to my gauges.
Is the dimmer original equipment mate? Never seen one in escorts.
Old 17-01-2011 | 11:20 AM
Karlos G's Avatar
Karlos G
Balls Deep!
I thought about that and I do have a cracked one I can experiment on! But you can feel a lot of them with your finger nail so too deep I imagine
It is mate yes! Perhaps a Cabby only item, dont know?!
Old 17-01-2011 | 11:37 AM
Rogeyboy's Avatar
Rogeyboy
Yeh maybe a cab item as i havn't seen it on any other escorts or orions even... Good idea tho!
Karlos i may have a scratch free plastic if you need it m8.
Old 17-01-2011 | 01:59 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I had three to choose from and even the least scratched one once fitted and the dials were illuminated looked terrible, the light they emit is a lot more direct than stock dials and really shows them up, I bet if you look closely yours will have more scratches than you realise I didnt think mine was scratched at all until I fitted these dials, thanks very much for the offer though I appreciate it!
But... I have just spent an hour polishing mine and it looks amazing!! :O
The difference is truly incredible I've never seen one look so clear, almost like glass now! I just hope it looks as good at night when the dials are illuminated?!
What I did was use 800, 1000, 1200, 1500 grit wet and dry with warm soapy water and then plastic polish on the outside face, then just the polish on the inside as this had almost no scratches, works a treat
Old 17-01-2011 | 02:19 PM
RUBY123's Avatar
RUBY123
this could be of some use to you
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
Old 17-01-2011 | 02:26 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Wow good find!!
Old 17-01-2011 | 06:48 PM
craig2351's Avatar
craig2351
Looking good mate, I've just put a stack display in mine
