2wd calipers
hi all. iv gone and done a twatish thing and brought 2wd front caliper, 2wd front discs, yellowstuff pads and braided lines and had the caliper machined by 4mm and had my hubs drilled and tapped to m12 so i can fit them to my rs1600i that im restoring from the ground up. im just waitting on my gaz coilovers to turn up so i can fit them but iv just read in old posts that the 2wd front brakes dont fit under s1 wheel and im totaly gutted!!!
what is it that causes them not to fit under the wheels? is there any way at all to make them fit? can i machine the face or the caliper a little and fit wheel spacers?
i really need help on this so any advice would be great
thanks
thanks
Will it ever end !!!!!!!
Pretty sure you will find that you need 4wd discs to go with 2wd calipers (4pots) as its the other way round for 4wd calipers (ie 2wd discs with 4wd calipers) if using 15inch wheels.
Pretty sure the calipers will then fit.
Maybe someone else can confirm?
I really need my coilovers to turn up so I can play around with them and see what the problem is but there not due for another 2 weeks so in tryin to find out as much as I cam till then
wrong im affraid i had 2wd disc's and calipers on my estate once the 4mm is machined off the caliper it sat smack bang in the middle of the disc
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
