which management
think i have asked this before. but i am going for aftermarket management on my cvh turbo.
i just dont no which management to go for.
cosworth management,
megasquirt
omex
and probs alot more.
my engine is going to be standard pritty much so will be wanting anything over 200bhp at fly.
i am going to speak to msd to see witch they prefer mapping as they are the most local tuners to me.
any help would be great joe
megasquirt
omex
Omex Joe. Fantasticly easy to set up and works brilliantly. I also have a base map that will start the car once fitted
MSD won't touch Pikeysquirt as then can't rely on the quality (if the ECU fails and destroys an engine, they don't want their map blaming for it).
I am thinking omex a mate is selling a complete kit for efi conversion. Will you be a the next meet daz. Starting now stu gona be stripping and tidying engine bay in new year.
Thanks for the comments
Funny how theres a question regarding management every week lol
Always the same out come as well, your always going to get people saying there systems good and others saying there bad or that they have had a bad experience.
As far as I'm aware
omex
gotech
megasquirt
pectel
cossie
Have all at some point made good reliable power on loads of cars ..... pick the right mapper/tuner and in most cases your going to get a good setup.
As far as I'm aware
omex
gotech
megasquirt
pectel
cossie
Turbocharging Technician
lol cars used to have carburetors lads, and still won races, calling megasquirt pikey when you personaly cant build one, wire it up and tune it and prehaps even fix it if it goes wrong (as all electronics can) is a bit of a poor comment, the pros of such a system are pretty much the cons too, as you need to be half intellegent and know what your doing in the first place to use it, but yes if you make a mistake it can go wrong, but then im sure many proffesional tuners have cooked expensive ecu's also, if you dont know about electronics, wiring or computers then go to a tuner and get them to do everything, and then get your wallet out. And if it goes wrong then take your car back and get your wallet out again, and if you change your spec get your wallet out, (you see where im going?) but if you are reasonable at electronics, wiring, electrical systems and engine tuning then use a system that is cheap and suits this, be it MS or similar diy ecu. Basically it comes down to ability, time and money, someone with MS will rarley get it proffesionaly tuned as that is not the type of person they would normally be. I hope this helps, thanks chaffe
A few might well be over priced but others won't be.
My point about MS is it is cheap and budget with crude yet effective abilities. More costly ECU's have a lot more accurate load sites and facilities/abilities. It is fine for people who like to tinker. In fact it's probably ideal for someone who likes to timker. My own ECU is massively more complicated than MS and is not as user friendly, not by a long way!
My other point about MSD not wanting to map it is that the build quality of the MS ECU's is always questionable and a dry soldered joint could fail at high load and destroy an engine. The fault may not be noticed until after another engine has been destroyed and another remap. By that time MSD have had their name dragged through forums and muddied by having their map slated as the cause of the engine dieing. They just want to keep their name away from that possibility.
mk3ste
17-10-2021 10:09 AM
deathrider666
28-09-2015 06:12 PM
