boost hose clamps
Old 21-12-2010, 10:10 PM
martinmilne
martinmilne's Avatar
Default boost hose clamps
what are the best and most reliable ones to use as mine are fucked and dont want to get crappy ones that loose all the pressure
Old 22-12-2010, 07:55 AM
kermitt
kermitt's Avatar
Mikalor clamps. Check out Autospecilists site as they do a kit for your boost pipes. If the sizes are there then check around to see if u can get them cheaper elsewhere.
Old 22-12-2010, 08:23 AM
Karlos G
Balls Deep!
Karlos G's Avatar
NOT Makilor clamps! lol
I ran them for two years until Christian said in his experience they leak badly, so I changed them for what he uses (look like double width jubilee's) and gained 7psi of boost, I actually had to turn my boost controller down because I hadnt mapped for that much boost before!
Old 22-12-2010, 09:45 AM
morph
morph's Avatar
+1 mikalor clamps dont seal properly you have to virtually over tigten.
only clamps that are proper good are jsl clamps but expensive.
Old 22-12-2010, 12:56 PM
xrmalin
xrmalin's Avatar
My mate had the same problem with the mikalor clamps on his cossie looseing boost, swopped back to normal jubilees and it was fine again
Old 23-12-2010, 10:41 AM
kermitt
kermitt's Avatar
These look nice;
http://www.prolockhoseclamps.com/index.php?page=gallery
Old 23-12-2010, 10:58 AM
dojj
Resident Wrestling Legend
dojj's Avatar
Originally Posted by kermitt
they do indeed resemble canine testicals
Old 23-12-2010, 12:31 PM
Karlos G
Balls Deep!
Karlos G's Avatar
They do look nice, but IMO will suffer the same problems as Makilor.
IMO the double width Jubilee style ones Christian sold me tighten up 360deg so to speak, not just squeezing at the top and that then translating down the sides and leaving the bottom with little clamping force and an almost raised section of hose where the clamp is squeezing.
Hard to describe but I hope you get what I mean?! lol
Old 23-12-2010, 07:21 PM
martinmilne
how much were they karlos and can they be sourced from anywhere or should i give christian a pm?
Old 23-12-2010, 08:44 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Think I paid about £10 for a full set, I'm sure you can get them from many places but I dont know of any as I got them when I was having my power run.
Christian is wank at answering PM's or emails, your better off calling him and even then the phone is either engaged or he doesnt answer!! lol
Old 23-12-2010, 09:06 PM
Danster76
Danster76's Avatar
I think I bought mine (sound like what karlos is describing above) from roose Motorsport.
Old 24-12-2010, 08:19 AM
martinmilne
anyone got a pic ? do they just look like a double sized normal one
Old 24-12-2010, 10:28 AM
Karlos G
Balls Deep!
Karlos G's Avatar
Here are mine....
They are maybe not double width, but more like 1.5x the width of a normal Jubilee.
Old 24-12-2010, 10:46 AM
RichieST
RichieST's Avatar
We use bog standard jubilee clips to hold hoses on to military aircraft engines at work. Good enough for this job, good enough for a Ford IMO!
Old 24-12-2010, 11:32 AM
martinmilne
cheers karlos
Old 24-12-2010, 12:00 PM
Karlos G
Balls Deep!
Karlos G's Avatar
No probs mate thought it easier to just nip outside and take a pic for you!
Old 24-12-2010, 12:20 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
i just use nornal jubilee clips and have not had any probs and i run 2.6 bar
Old 24-12-2010, 06:13 PM
ROB7656
ROB7656's Avatar
auto specialist do the thicker jubilee,s.
01-11-2015 06:53 PM
Fudgey
21
30-09-2015 06:19 PM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: boost hose clamps
