MegaSquirt Experts
Just fitted my ms2 ecu but having trouble with the car not starting. Got a spark, fuel pump is giving 3bar so must have a setting wrong.
basic spec
36-1 trigger wheel on the crank
1.8zvh
ms2 ecu
grey injectors
any tips or things to look out for?
basic spec
1.8zvh
ms2 ecu
grey injectors
are you actually seeing RPM on the laptop when cranking? If so next thing to test is if you have a signal at the injectors. Disconnect each one, put an led across the terminals (only works one way remember!) and crank - you should see it flashing.
Rick
Rick
DavidK
27-09-2015 02:55 PM
