What hose kit
Old 16-12-2010 | 02:35 PM
cossirob's Avatar
cossirob
Default What hose kit
Iv just put a fiesta rs efi engine in my mk3 escort shell and wanted to know what samco/Roose hose kits will fit s1 s2 or fiesta??
Thanks
Old 16-12-2010 | 05:00 PM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
fiesta m8
Old 16-12-2010 | 06:57 PM
drsrst2zvh's Avatar
drsrst2zvh
Are you running a t3? Also do you have the fiesta turbo crossover pipe and rocker cover?
Old 17-12-2010 | 08:26 AM
Chris69's Avatar
Chris69
I used the Roose s2 rst kit- the only one that didn't fit if i remember right, boost hose wise was the crossover to the T/B connector.
I used the FRST crossover.
Old 17-12-2010 | 09:47 AM
cossirob's Avatar
cossirob
Hi thinks for your replys, Yes I'm using a t3 with the fiesta rocker cover and fiesta crossover pipe??
Thanks
Old 17-12-2010 | 11:05 AM
CarParts Express's Avatar
CarParts Express
if u let me know exactly what u need i can arrange a custom roose set for you
Old 17-12-2010 | 01:02 PM
Rogeyboy's Avatar
Rogeyboy
I have EFi inlet and crossover with Series 2 intercooler and T3 and the fiesta pipe was too short to reach from the crossover to the intercooler.
I had to chop the "over pipe" on the crossover back to the ford badge and use a Series 2 top boost hose, which just fits!
I need some custom hoses made up really - Samco apparently so a kit for EFi converted Series 2's!
Old 17-12-2010 | 08:39 PM
drsrst2zvh's Avatar
drsrst2zvh
What you need to do is use the standard rst rocker cover and cross over pipe that way you can use the series 2 kits and the only hose you will need that is different to standard is the cross over pipe to throttle bodie as it will have to reduce slightly thats what i would do job done.
Old 18-12-2010 | 09:52 AM
cossirob's Avatar
cossirob
Will this be the same on a mk3 escort with an efi rs engine? Also is that both the boost and Ancillary s2 kit il need?
Thanks
Old 18-12-2010 | 12:34 PM
drsrst2zvh's Avatar
drsrst2zvh
Yeah you will use the entire set ancillary water and boost bar that 1 pipe. If it's just the inlet that is different is using a u2 and standard mounting intercooler etc...
Old 18-12-2010 | 11:06 PM
Rogeyboy's Avatar
Rogeyboy
But what if i/we wanna keep the EFi crossover pipe?
Old 19-12-2010 | 01:13 PM
drsrst2zvh's Avatar
drsrst2zvh
If you wanna use the efi cross over pipe then buy the frst t3 boost set
01-11-2015 07:53 PM
Fudgey
21
30-09-2015 07:19 PM
PRO-LINE MOTORSPORT
28-09-2015 10:54 PM
Quick Reply: What hose kit
