Standard T3 Manifold - Wrapped?
Old 07-12-2010, 07:09 AM
Rogeyboy
Rogeyboy's Avatar
Default Standard T3 Manifold - Wrapped?
I've got a standard T3 manifold which i have exhaust wrapped, but some people tell me it will crack once wrapped. Mine glows red after even gentle driving and im worried it might crack...
Whats the opinions on this?
Is it normal to glow red?
Old 07-12-2010, 08:09 AM
ZTSI
ZTSI's Avatar
Mine glows red after a spirted drive. T3 manifolds are cheap, wrap it and see what happens.
Old 07-12-2010, 08:29 AM
muz
Wye Valley Hardcore
muz's Avatar
Mine cracked after it was wrapped. Whether it was a coincidence I don't know, but your not supposed to wrap cast.
Old 07-12-2010, 11:45 AM
Rogeyboy
Rogeyboy's Avatar
Muz - Did yours glow red after driving?
Mine seems to glow quite easily... Just wondered if they'll crack after a while, but alot of ppl seem to wrap them. Twins has his wrapped etc.
Old 07-12-2010, 01:31 PM
zetecherb
zetecherb's Avatar
on my old rs at one point it glowed white, i had ago at wrapping it and after i got a telling off from a car garage so off the wrap came it was a t34
Old 07-12-2010, 02:27 PM
essexRSTSouthend
essexRSTSouthend's Avatar
I always see aftermarket manifolds saying warranty void if wrapped.my manifold cracked and thats without wrap.
Old 07-12-2010, 02:31 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Then there is something wrong mate, either too lean or to retarded, get it setup asap IMO!
Old 07-12-2010, 03:11 PM
muz
Wye Valley Hardcore
muz's Avatar
I missed that, Karl. It shouldn't glow red after gentle driving. Points to a fueling or timing issue. Has it been set up?
Old 07-12-2010, 03:14 PM
muz
Wye Valley Hardcore
muz's Avatar
Also Dave (twins) car isn't running big power, so he wouldn't see the same heat as some of us. Mine craked where the headers meet the the turbo flange.
Old 07-12-2010, 03:20 PM
mattseries2
mattseries2's Avatar
Mine too.
Old 07-12-2010, 04:12 PM
Rogeyboy
Rogeyboy's Avatar
When i say "Gentle Driving" i mean bringing it on boost at mid throttle/mid revs and then driving off-boost for 2-3miles after and pulling up and checking the manifold! Ive got the Idle CO set to around 3% but it needs a good set-up. I'm refraining from driving it hard until it's setup!
Maybe that'll cure my hesitation as it comes on Boost in 4th and 5th too!
My Inconel 4 branch on my NA CVH would glow after hard use once it was wrapped!
Old 07-12-2010, 04:22 PM
martinmilne
martinmilne's Avatar
i had mine wrapped and it blew the gasket it did glow red but after a good thrasing
Old 07-12-2010, 04:24 PM
Ade
Fast Ford snapper
Ade's Avatar
Glowing manifolds are bad news! Usually running really lean, get it seen to!
Old 07-12-2010, 04:31 PM
essexRSTSouthend
The flange gasket blew?
Old 07-12-2010, 04:52 PM
martinmilne
no the manifold gasket
Old 07-12-2010, 05:27 PM
essexRSTSouthend
Ford item? Just wondering.
Old 07-12-2010, 05:32 PM
martinmilne
no wasnt just all parts jobby
Old 07-12-2010, 06:15 PM
essexRSTSouthend
Ok.cheers
orionmojo
orionmojo's Avatar
I had mine wrapped for a bit Roger, i wouldn't bother personally. it did f**k all to underbonnet temps and it wsa nigh on impossible to get to a couple of bolts when it came to the refitting of it. once it was gone it was good riddence.
I did wrap my downpipe until past the gearlinkage though and that helped ever so slightly imo. (for underbonnet temps)
Old 07-12-2010, 06:18 PM
Rick
Rick's Avatar
No.
Old 07-12-2010, 08:14 PM
Rogeyboy
Rogeyboy's Avatar
I wrapped it to keep underbonnet temps down, but if its gna do more harm than good when i swap the turbo i'll unwrap it... Wrapping the whole system is on my to-do list, double on the downpipe!
Im just worried about it cracking as it glows red... Maybe i'll get it set-up and see how it goes!
Old 07-12-2010, 09:49 PM
Rick
Rick's Avatar
it's the exhaust valves you need to worry about. cracked manifold is the least of your worries.
Old 07-12-2010, 11:13 PM
essexRSTSouthend
Problems with valves only apply to standard?
Old 08-12-2010, 07:00 AM
Rogeyboy
Rogeyboy's Avatar
What happens to the exhaust valves? Arent they sodium filled to dissapate heat?
Does wrapping the manifold retain the heat in the valves... Won't the head still cool the valves?
Old 08-12-2010, 08:27 AM
muz
Wye Valley Hardcore
muz's Avatar
I thought only Series One exhaust valves were sodium filled? Not Series Two.
Old 08-12-2010, 10:11 AM
Rogeyboy
Rogeyboy's Avatar
Well i don't know, now you've said that lol!
I thought all CVH Turbo's had sodium filled exhaust valves...?
Old 08-12-2010, 01:45 PM
essexRSTSouthend
Im running big valve head,thought id ask lol.but then still got the problem of the manifold cracking i spose..
Old 08-12-2010, 04:18 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Yes
No
lol
Old 08-12-2010, 04:19 PM
muz
Wye Valley Hardcore
muz's Avatar
Yay! I win the prize!
Old 08-12-2010, 04:37 PM
essexRSTSouthend
If these valves were that good,surely ford would of carried it on to s2...
Seems strange to me
Old 08-12-2010, 04:50 PM
Chopshop85
Chopshop85's Avatar
I'm running 15psi making around 170bhp and my manifold has never changed colour lol, even after a spirited drive.
Get that car set up!
Old 08-12-2010, 05:35 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Seems strange to me
At 132bhp Sodium filled valves are utterly pointless, the chambers do not see temps any where near high enough! lol
I can only assume that as the S1 was more motorsport inspired they carried the valves over, remember they had them producing 250bhp+ for touring car racing back then.
Old 08-12-2010, 08:48 PM
essexRSTSouthend
Yay it was the 260 mark,as my uncle had a road version.crazy.
Old 08-12-2010, 09:10 PM
Rob_DOHC
Rob_DOHC's Avatar
Just better head transfer to the head, they are bastard expensive to get made, haven't found any off the shelf
Wouldn't have thought heat wrapping the manifold would have any effect on actual valve temperature tbh.
Rob,
Old 08-12-2010, 09:22 PM
essexRSTSouthend
Since this topic started i've been trying to find out if it worth the hassle lol.
Old 08-12-2010, 09:30 PM
Rob_DOHC
Rob_DOHC's Avatar
What, sodium filled valves or wrapping the exhaust?
Both are worth it, just not practical.
Old 08-12-2010, 09:44 PM
essexRSTSouthend
wrapping.i just keep coming across cracked manifolds due to wrap..
Old 08-12-2010, 10:11 PM
Rob_DOHC
Rob_DOHC's Avatar
Manifolds are cheap, give it a go and let us know lol
Rob,
Old 09-12-2010, 12:40 AM
essexRSTSouthend
haha.Nah im ok thanks
Old 09-12-2010, 07:06 AM
Karlos G
Balls Deep!
Karlos G's Avatar
Quick Reply: Standard T3 Manifold - Wrapped?
