Spark blow out on boost?
#41
The inductors do get hot, i never said they should get as hot as yours!
As i explainered to you, half of the driver board is there simply to drive the tacho, so i suggested running it with that part disconnected.
we would be more than willing to take a look at it if you book it in, but i cant test or diagnose the issue without seeing the car really, The driver install looked ok, apart form the board being fitted upside down, but i cant comment on the history of the driver itself or how it may have been fitted before which may have damaged something internally.
i dont know what else i can suggest really apart from book it in, leave it with me for a day, and i will see if i can fix the issue.
we fit quite alot of these, and none have suffered this issue before.
#42
James the car will be with me at some point so ill have a look at the driver and the rest of the system. Its caused him loads of headaches and has made him miss a couple of shows and track days which is a shame. Ill update with my conclusion so it might help others in the same position.
#43
indeed mate, if it is a faulty driver then fire it back to me and we will replace it. but im sure there is something else causing the issue tbh
#44
Its all removed and back on a distributor set up, I've had to take a step backwards togo forwards.
Jano I will be with you tuesday for my set up and whatever else you think is needed.
#46
#47
PassionFords Creator
Jano, its easy to look at this circuit. Simply disconnect pin 20 INSIDE the ECU, IE: Cut the orange wire, that will totally disable the tacho drive circuit on the board.
You can then use a diode pack to drive the tacho direct from the coil.
Job Jobbed.
#49
Im now glad i bought a ms2. jano and stu are the best people in the trade to sort this and hope you get it sorted soon. fingers crossed for you.
#50
Hello Studabear,
Just for us (Canadians) who are unfamiliar with the UK factory type ecu.
Is the wasted spark driver a add on component or circuit board?
Here we typically use a Bosch wasted spark driver - low cost and dead reliable.
Perry
Perry
#51
Hi perry its an ad on board for the cosworth L6 ecu's L8 also,
I was running the wasted spark conversion on my cosworth managed cvh turbo engine.
heres some more info for you
http://www.motorsport-developments.c...stedspark.html
#52
Thanks for the information.
That looks like a great bit of kit!
Provided it has been assembled correctly of course.
I don't understand what a tachometer would draw too much current? Is there not a current limiting resistor in series with the diodes?
Cheers.
Perry
Cheers.
Perry
Mark RS
12-10-2015 06:01 AM
deathrider666
28-09-2015 06:12 PM
SMILER258
28-09-2015 09:04 AM
Russ Payne
25-09-2015 08:29 PM
