got a problem!
Old Nov 20, 2010 | 07:20 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default got a problem!
tomorro im taking the driveshafts off the s2 but the car is on axle stands, how can i undo the driveshaft nut at the hub, if the car isnt on the floor with wheels on?
Hope it makes sense.
Old Nov 20, 2010 | 07:24 PM
escort_rst's Avatar
escort_rst
put in gear and get someone to press the brakes or put something in the vented discs and wedge it up against the caliper carrier
Old Nov 20, 2010 | 07:25 PM
chaffe's Avatar
chaffe
Turbocharging Technician
as above, press the brakes, dont damage the discs by jamming something in them though
Old Nov 20, 2010 | 08:12 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
i have no brakes on the car, so if i put it in gear will it be ok to just undo it that way? then just basically tap the driveshaft out the hub and pull it out the gearbox?
Old Nov 20, 2010 | 08:13 PM
chaffe's Avatar
chaffe
your going to struggle lol, first thing you should of done
Old Nov 20, 2010 | 08:19 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
ill get the spare wheel out and put it on each side and crack the nut best way?
Do the shafts just pull out the gearbox? and just tap it out the hub end?
dangerousbrian's Avatar
dangerousbrian
i made this mistake before, had someone one the brakes and in gear, and nearly lifted the car off the axle stands trying to undoe the nuts..not something i would reccommend personally..at least not with that technique anyway
Old Nov 20, 2010 | 08:22 PM
dangerousbrian
yeah..you might have to renmove the bottom arm from one end to enable the hub to move enough..had to do that on my s1 but didnt have to on my mates rsi
Old Nov 20, 2010 | 08:24 PM
phil_focus's Avatar
phil_focus
thats why you shouldnt be pulling up, you should be pushing down!! that way the car stays put and you dont risk the car sliding off the stands!
ith no brakes your gonna struggle so use the spare wheel. providing theres enough of the cars weight on that wheel when its on the ground and the car cant move then you'll get them off.
155lee's Avatar
155lee
2 wheel studs and a pry bar between them and pressing against the ground.simples.
Old Nov 20, 2010 | 08:29 PM
dangerousbrian
the nuts were on that tight, there was no way they were coming off pushing down..couldnt get enough strength into it..might get more muscles for the next time ha..and the car felt like it was moving anyway..
Old Nov 20, 2010 | 08:31 PM
turbocabs's Avatar
turbocabs
Thumbs up
as above best way and safest
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
as i have never took the shafts out, how long you think it will take a first timer?
Old Nov 20, 2010 | 08:39 PM
155lee's Avatar
155lee
15 minutes a side.mind,the left hand side (iirc) is left hand threaded.dont pull up on the breaker bar,stand on it,that way you wont loose teeth when it comes slack or lift the car.once youhave it slackened off a few threads use the hub as a sort of slide hammer,this will pull the inner cv out of the box.put some rags down as the oil runs onto the engine cradle and drips everywhere.it helps to have the steering lock off as to get the shafts out of the box or out of the hub you need to turn the hubs in at the front by pulling the back out,i.e to get the n/s shaft out turn the wheel full lock to the right,then pull the hub out at the front and that will give enough clearance for the shaft to slip out.you are going to have to undo the bottom ball joint,the pinch bolt simply taps out after undoing the nut then use the pry bar to lever it out of the hub.
Old Nov 20, 2010 | 08:46 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
ok thanks very much, ill be up early, to start on it hope i do it ok, im going to take the drivers side shaft out first.
Old Nov 20, 2010 | 08:56 PM
BRAM's Avatar
BRAM
I do'nt think the left hand side was left hand thread.
Cheers Bram
Old Nov 20, 2010 | 09:19 PM
dangerousbrian
Cheers Bram
yes..def not a left hand thread..just done mine not long ago so still fresh in my mind
Old Nov 20, 2010 | 11:22 PM
nigel b's Avatar
nigel b
if you only want to take the shafts out why not take them out from the cv joints
its only a circlip
Old Nov 21, 2010 | 05:29 AM
155lee's Avatar
155lee
Cheers Bram
i was thinking that after i wrote it,must be the right hand side.
Old Nov 21, 2010 | 09:02 AM
white2lsr's Avatar
white2lsr
Its one side of the anti-roll bar thats L H threaded. Drivers side I think
Old Nov 21, 2010 | 11:02 AM
155lee's Avatar
155lee
i remember that,on a cossie 1 side is left hand threaded,didnt really pay attention when i stripped my s2,just assumed it was the same.hopefully he has done it by now and he has it in bits.
Old Nov 21, 2010 | 11:50 AM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Yep,all done, couldnt undo the hub nut, so just took anti roll bar off, TCA off, and track rod end, then just one pull they both came out, the drivers side just came out with ease,
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
