Can you still get these parts from ford?
Doing a front end resto and need all the nuts/bolts/washers for the suspension eg.
Lower arms bolts/nuts/washers
Steering rack bolts and nuts on the ends
ARB washers and nuts
Lower arms to hub bolts
And what ever else ive missed?!
Lower arms bolts/nuts/washers: yes, bolts, nuts and washers available for lower arm to body mount, and then torx head bolt and nut available for the balljoint end.
Steering rack bolts and nuts on the ends: to hold to the bulkhead? i just used new m10s, 20 or 25mm i think. nuts for track rod ends to hubs are available from ford too
ARB washers and nuts: washers and nuts for front yes, never enquired about rear
Lower arms to hub bolts: as above, torx head bolt and nut available
let me have a look in the garage before u go buyin anythin from ford tho, im sure i still have bolts and nuts for the lower arm to chassis mount, possibly the lower arm to hub aswel
155lee
14-09-2015 07:37 PM
borboyous
22-08-2015 11:17 AM
