S2 sunroof rot - Replacing sunroof panel assistance?!
Hi,
I started stripping my S2 rst which i have owned for the last 12 years, and was hoping to do a bit of welding and a bit of blowing in of the paint work. I have now got the car stripped to a bear shell and found rot everywhere (its amazing how a mint looking car can be so bad underneath all the plastic and interior)!!! should just re-shell but as I've had the car so long Im gonna stick with it. It need rear quaters, front panel, rear panel, inner arches, battery tray, full scuttle, floor panels and chassis sections etc etc!! at the same time Im converting to Cos management, Gaz coilovers, Big brembo f3 brakes and reconditioning and replacing everything that is needed.
Anyway, I got the sunroof out which needs replacing and roof lining down. The panel which holds the sunroof runners and which the sunroof slides back into is badly rotten and has started to rust through to the outside causing the paint to bubble (common I know). I would like some advice or links to threads that could help with the following-
-Is the panel welded or just sealed into place (I cant see any signs of spot welding)
-How do I remove the panel?
-Is there a replacment panel available?
-has anyone done away with the sunroof completely and if so how and what roof lining did you use??
Any other help woud be great.
If anyone is interested I will start a thread in the restoration catagory.
Thanks Sam
Thanks Sam
competant bodger
if you want to get rid of the sunroof you are better off just welding a roof skin on off a non sunroof model mk4 and using the non sunroof headlining or a 16i headlining its not as bad a job as you would think, or you could bond a carbon roof onto your existing roof?
sounds like theres lots of work and money to be spent there, if its that bad i would be tempted for a re-shell, look for a near perfect shell and transplant all the bits over, not your original car i know and prob not the advice you were wanting, but its much more economical in the long run,
best of luck jonny
best of luck jonny
The sunroof tray is spot welded in mate. If you look from the top of your roof where the sunroof sits there are spot welds around the top. you should see where the two skins meet. then under it is bonded on. Don't just try to pull it off when you've drilled the welds out because you will just crease the roof and you will never get it right after that. you will have to cut it off like cutting a windscreen out.
hope this helps
lee
hope this helps
lee
best of luck jonny
best of luck jonny
hope this helps
lee
hope this helps
lee
Hi mate iv a full roof of a origanal rs turbo tiny bit of rust on it i was going to do a full roof swap on mine but its not as bad as i first thought im up in bolton and im open to offers for it cheers
Yes I know your right, Even if I was sensible enough to go for a re-shell I think I would struggle to find one good enough. I want to do the work so i can be 100% happy with how good the car is. The welding and sand blasting will cost me nothing, Quality pattern panels are cheap enough. Just the painting may cost a pretty penny. Hows your car coming on??? (I bought the Cos management from you). Wanna swap shells?!?!
finished the grey one sam
hope all is well mate
lol, i know what your saying mate but ive been thro it all many a time and altho its nice to do the work yourself, when you have soo much to do it just gets too much and the time will come when you just want to use it especially summer/show season, you want the one in the garage lol.
I'm gonna go ahead anyway, you can tell me 'I told ya so' when I have to drive my escort diesel runner to the shows.
lee
I got this in a PM from Phil who I contacted after reading an older post, Thought I'd paste it here in case it is of any help to anyone else in the future.
alrite sam,
nope its not a problem at all, basically in a way i got mine sorted but as i was out to just try and stop the rot all i did was do away with the sunroof completely by cutting the old one out and replaced it with a piece of sheet steel, this was meant to be a temporary fix until i could sort out somthing more permanant but then i found the rest of the car to be rotten so ended up scrapping it, basically when i cut mine out i had no intentions of refitting it and the underside of the roof looked like this:
http://i57.photobucket.com/albums/g2...0102009253.jpg
and the actual tray when i'd got it out looked like this:
http://i57.photobucket.com/albums/g2...0102009254.jpg
the sunroof tray is spotwelded around the front and a couple at the back then its just pretty much tigersealed in, like i said as i had no intention of putting mine back in, i drilled out the spotwelds on the back with a spot weld drill, then heated up the tigerseal to get it soft and just peeled it back to the front, i then took a thin cutting disc on a grinder and cut around the inside edge of the actual sunroof hole, then it pretty much fell out, then i got the piece of sheet steel and bolted it in with stainless steel allen bolts with some tigerseal to to seal it, after i'd finished it looked like this:
http://i57.photobucket.com/albums/g2...2102009259.jpg
http://i57.photobucket.com/albums/g2...2102009258.jpg
and the inside looked like this:
http://i57.photobucket.com/albums/g2...2102009260.jpg
i hope this helps even a little bit, it all depends how far you wanna go with the repair, i mean if your like me just trying to stop the rot thats a perfectly good repair untill you get summat else sorted, or you could always get a carbon roof etc or see how rotten the rest of the car is, if its bad maybe a reshell, its up to you,
anyways like i said hope this helps and i hope you get it sorted,
Phil
alrite sam,
Phil
chowfornow
14
05-01-2019 09:01 PM
155lee
06-09-2016 11:10 AM
