leaking rs turbo ready to pull my hair out!
having problems when i rains, water leaking in from behind dash coming from battery tray area and fuse box area, sealed it a couple of times now yet everytime it rains i get two puddles in both sides. took ther dash out to day used silicone and bitumen paint put loads on trying to make sure it was sealed also sealed in round fusebox and battery tray. its still leaking!! anyone got any help or advice please its really doing my head in now!![Wall](https://passionford.com/forum/images/smilies/wall.gif)
thanks
Neil
thanks
Neil
windscreen seal, sunroof drains, door seals to name but a few, maybe take all the carpet out and get in when it rains, see if you can spot the leak
Was a slight hole in the top corner behind the globox side of the dash. Just cut out the rot and plated up the hole and finished with seam sealer either side. Gotta wait for the sealer to cure before I test it. I should think thats its solved as there was no other rots and everyhting was checked!
As already said, it could be one of many things. Water has a tendancy to run along the edges of things so it can be really hard to find sometimes. Try taking the carpet out and chucking flour on the car whilst having the hose on it. The flour makes it easy to see once it starts leaking through.
I've also seen them rot out behind the brake servo! the one thing to check is all of the drains, they dont take much to block and once they have the y will soon overflow into the car.
Matt Baxter
16-09-2015 08:30 PM
JoeyBoyden
18-08-2015 10:52 PM
