fuse box
when you lift it up the loom goes through to the car, the only way i see of disconecting it is to either pull all wires from the connectors or cut and re solder after the work is done, anyone have any better ideas as to me it seems a right arse on.... lol
Any help would be great.
if you are wanting to remove the fuse box from the car then you need to remove the whole loom from inside aswell as its all one piece. i wouldnt even think about cutting it and resoldering the loom, think of all the problems you would have after doing that plus i would be constantly thinking it was going to burn the car down
no mate no such thing, i know its a fuck about but its interior out and pull it all through. The only way to ensure it can all go back together as it should.
GOOD LUCK !!!
GOOD LUCK !!!
Steve Escos
01-10-2015 06:57 AM
deathrider666
28-09-2015 06:12 PM
Russ Payne
25-09-2015 08:29 PM
