benefit of having ABS removed?
The posh are up!!!
thinking about doin this as my pedal feel is shit and i have upgraded to cossie front brake,
can anyone send me a picture guide on how to remove the abs etc?
![](http://i410.photobucket.com/albums/pp182/craig2351/absguide1.jpg)
heres a picture of what pipes go where just cut all the old abs out, and make some pipes up to go from the cylinder to the t piece on the inner wing then the extra holes on the brake resvaoiur you can either change for a none abs one or link the two up with a bit of pipe
in the garage
hope it works like in your diagram as i have removed mine and piped it up referance this picture, seems 2 have bled up ok but its still sat on stands in the garage!!!! any1 else used this as a guide and no if it works 100%?????
