Remove water pipes on stage 2 t3 rst s2
Hi
Want to get better water temps on summer days after fitting a front mount intercooler in my RS Turbo S2.
Is it a good idea to remove water coolant pipes on Stage 2 T3 turbo buyed from CRTurbos?
I read that only "roller bearing turbos" need water cool........
Thanks in advance.
Thanks in advance.
My car is running with airtec turbo cooler but it is not enough to drop water temps...........
competant bodger
best thing i did to my rs for dropping the water temp
NO NO NO! the braided one is the oil feed mate, the water pipes are two metal pipes one either side of the turbo held on with bolts just remove these and locate the rubber pipes they fit into and block them with bolts (the rubber pipes)
i plan to connect mine back up, i often do short journeys alot of start stop, got twin fans 11" .82deg thermo with the uprated msd fan switch and a pre rad (turbo cooler thingy) not yet tested the system, will soon find out
JK12
33
26-04-2021 12:09 PM
