siemens injectors 55lbs
guys will siemens injectors 55lbs be able to flow enough fuel for 270/280bhp on a 1600cvh fitted with gotech and stage 3 t34 .48 (nms spec) as a friend has a set to cheap to say no realy
thanks
thanks
630cc DEKA IV's are the ones to go for IMO, not the cheapest, but around £200 inc tax etc you can get them from the states and will flow around 125bhp a piece on a good BSFC, more than likely 75-80bhp per injector @3BAR on an rst though.
so the deka's are bigger than the siemens black's but are they bigger than greys as any of them will work with my ecu but i just dont want to run my injectors flat out so im looking for something that will run 270bhp and run that safely.
cheers
cheers
greys will piss that power on a cvh, we are running 300ish hp on them in a cvh no probs.
the guy i brought the turbo off was running greens at 289bhp but with a better cam but the greens where maxed
wicked guys well its coming apart again this weekend and having my new bits fitted ...
im fitting a cts box with atb ect and vibratec gearbox mounts and t34 and down pipe and ive got a monster air filter aswel... and i will just take a set of greys with me when i get it mapped and then if they are needed then they can be fitted.
then if someone buys my turbo quick i can get those 6pot brakes
mk3ste
Oct 17, 2021 10:09 AM
timsrs
22
Sep 24, 2015 08:14 PM
Thanks buddy
