Paddle clutches
Paddle clutches
For those how drives with paddle clutches every day, How does it feels? Is it nice or a hell?
There are sintered and cerametallic but I dont know the different.
The thing is, I dont want to destroy the gearbox.
BR Butchi
BR Butchi
4 paddles are a nightmare get the clutch pedal conversion done like ap say and your be alright. Also if your running enough power to need a 4 paddle id look into uprating that box otherwise it'll last 5minutes.
i running a 4 paddle for some reason it supposed to be normal for it to judder in 1st gear so i rev it in1st gear a bit more to prevent it i hate it but its good for later when u keep up rating the power .. if that makes any sense lol.
They good.Not that bad to drive with apart from when you in loads of traffic.You be walking around with one leg bigger than the other.apart from that they fine.Mine lasted two years before it gave up.torque on the clutch aint that high tho.
I've got a Helix 4 paddle clutch, quite easy to drive not that hard the only fault with it is when I go into reverse it makes a horrible screeching noise and when I'm driving along when ever I release the clutch peddle in 1st, 2nd and 3rd sometimes it makes a slight noise but I was told by Jamie at Jamsport that some of the Helix clutch's do that and there is nothing he can do about it.
__________________
186bhp with 205ft at 15psi
Italy World Cup Winners 34* 38* 82* 06*
well mate that happened to me and then it just messed up completely . that sound is your ratchet slipping a teeth back down and up . pm me ill explain
__________________
