Alloy Quadrant
As above does anyone have one of these, been searching for ages and cant find one anywhere gotta get one as i hear the plastic ones just break even when modded. Anyone help me out?
Balls Deep!
This is where I got mine but they are showing no stock ![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
http://extremesportsproducts.com/ind...d&productId=17
Oh heres one on ebay...
http://cgi.ebay.co.uk/Escort-RS-Turb...item1c1484d35d
The hydraulic conversion maybe something ill consider in the future. However for now i just want to do the clutch pedal conversion. Jano do you modify the mk5/6 quadrant as it shows on the ap website? and also which cable should i be using?
Think i might just try the plastic modified one.
Ask me a question!
I use both setups depends on what the car is used for. The adjustable setup is easy enough to do with the std pedal. Just drill a hole in the pedal weld a nut and use an old headbolt to adjust the height.
Or take the whole pedal box off and fit the mk5 setup.
Or just leave it as it is with std setup just new items.
Like i said above my car has never given issues after all the abuse its given.
Yeah I'm talking ap organic 4 paddle. So I won't be changing the cover plate. I think ill change the pedal for the mk5 and also modify the quadrant along with a non abs cable and then see how it is if its still not better then it'll be going hydraulic.
Problem is Karlos that when i first put the engine back in and went to select gears i couldnt get it into reverse i mean physically couldnt force it into reverse. Also when putting it into first the car was creeping with the clutch fully depressed. I had to change the hole which the cable ran through on the top of teh box and then to get any driveability i had to put 4 or 5 washers on the cable before it goes through that hole just to be able to get it into reverse. Thats why i think it needs the adjustable pedal conversion. I know that the 4 paddles judder when you first pull away and when manouvering the car around but surely it shouldt be acting the wayi have described?
So just to re-cap, if I do the pedal conversion it will sort out the creeping issues and in order to do that I need a mk5 pedal and ratchet and a "non" abs cable?
Balls Deep!
![](https://passionford.com/forum/images/smilies/roi.gif)
Ive just brought the pedal and quadrant from ford. But why does it say on the AP website that you have to put an m8 locknut on the back of the bolt adjuster??? what does it do?
07-10-2015 12:56 PM
