intercooler, bigger always better?
Old 03-08-2010, 05:03 PM
john_d
john_d's Avatar
Default intercooler, bigger always better?
can you have an intercooler that is just too big for turbo/engine? or is biggest always best?
Old 03-08-2010, 05:37 PM
JamboRS
focus rs 1672
JamboRS's Avatar
bigger is not always better
core design and airflow to it are much more important
Old 03-08-2010, 06:11 PM
dave_s2_rst
dave_s2_rst's Avatar
sorry to hijack the thread, but ive been looking at a few now, most would say go for grs, but would an airtec be suffice? Not really concerned with cost, just in desperate need and grs has a bit of a wait
Old 03-08-2010, 06:15 PM
milesy23rst
PUG 306 GTI-6
milesy23rst's Avatar
GRS are very good but airtec have had great results and are superb value for money
Old 03-08-2010, 06:27 PM
orionmojo
orionmojo's Avatar
thats what i have heard, but aren't they really heavy?
not that it matters too much i suppose.
Old 03-08-2010, 07:01 PM
milesy23rst
PUG 306 GTI-6
They are heavier yes but they still work very well
Old 03-08-2010, 08:00 PM
Rob_DOHC
Rob_DOHC's Avatar
I've had a grs and now have an airtec, i haven't run the car with it yet but i wouldn't exactly describe it as being heavy, a little more than the grs but not massively.
And yep bigger is not always better, the bigger the intercooler, and the longer the pipe work the greater the lag. This is one of the biggest arguments for a good charge cooler.
Ultimately an intercooler will give cooler act and the larger the intercooler (generally if well designed) should in theory give lower act's.
Rob,
*****EDIT******
What a total bellend, i actually have a radtec not an airtec so any thing above substitute airtec for radtec lol
Old 03-08-2010, 08:02 PM
dave_s2_rst
cheers for the responses, at what point would an airtec be hitting its max? Would like to go zetec turbo, currently zvh on 14psi
Old 03-08-2010, 08:05 PM
milesy23rst
PUG 306 GTI-6
Imo if you are going zetec turbo then go for the grs mate
Old 03-08-2010, 08:31 PM
Rob_DOHC
Rob_DOHC's Avatar
GRS is brilliant mate, although there was a post on here a while ago saying there was a test done a while ago or something and the radtec performed slightly better than the grs,
Grs is probably better quality and at a very good price, but there won't be any massive difference in air temps.
Rob,
Old 03-08-2010, 08:44 PM
diamondrst
diamondrst's Avatar
wot should the cars air temps b below 30c or below 60c i have a radtec front mount and im starting to think it doesnt do its job properly lol
Old 03-08-2010, 09:44 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Radtecs are spot on mate, TOTD done back to back testing aginst the GRS and both performed equally well!
I see around 35 running 27psi peek boost, obviously at stand still after a run that can creep up to near 60, but shouldnt be any where near that high when moving.
Old 03-08-2010, 10:21 PM
dave_s2_rst
karlos are running a radtec?
Old 04-08-2010, 06:40 AM
diamondrst
diamondrst's Avatar
When moving fast i see 29 to 31 when sitting rises to 60 but driving normaly i see 40 to 48 is this too high
ROB7656
ROB7656's Avatar
i run an airtech and it seems to do its job well compared to the old pace interwarmer i had. not a bad kit and simple to fit. only thing to consider is that the water temps are up as the rad is blocked by it.
Old 04-08-2010, 07:42 AM
diamondrst
diamondrst's Avatar
This is why i want a grs because i wanna put fans on the rad without cutting the bumper out
Old 04-08-2010, 07:51 AM
crazycage
crazycage's Avatar
what are your acts @7k in 5th
on a top speed run?
o
Old 04-08-2010, 08:09 AM
macrs
macrs's Avatar
Just to add to the mix....
I've been running a pro-alloy for three years and running temps have always been great. Had the pace 'interwarmer' previously and the pro-alloy one wipes the floor with it.
Mounted it with twin fans and no bumper cutting!
Old 04-08-2010, 09:36 AM
StephenC
..BS Motorsport..
StephenC's Avatar
NMS double cossie cooler always performed well on mine, my ACT guage from rainbum fooked itself a few months in to use but as far as I remember I saw very little heat rise from the cooler, under very harsh driving (ring).
Old 04-08-2010, 10:02 AM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
Firstly there is an optimum for everything. Either too big or too small is no good.
Too big and you will have lots of lag and lame throttle response. Too small is obviously high ACT temps.
From my experiance over the last 12years the GRS intercooler has always out performed every other intercooler i have used or worked with with genuine figures from diagnostics equipment and laptop etc.
Secondly the cheap ACT gauges available are not accurate at all. Many of my customers have them and when compared with real readings from a laptop the guage is more than 20 degree out at times. ? So anyone quoting figures without decent gauges is not worth bringing into the thread. Also i have noticed people guessing that their temps are better but how do you know. ?
Last but not least lets talk about weight of some intercoolers and the materials they are made from.
Regards
Old 04-08-2010, 02:28 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Yes mate!
on a top speed run?
o
Closest log i can find is at 6850rpm in 5th and ACT was 41c, I think that's as high as I have ever seen it when actually moving.
01-11-2015 06:53 PM
Fudgey
21
30-09-2015 06:19 PM
Fordmad!
29-09-2015 07:03 PM
Quick Reply: intercooler, bigger always better?
