base settings
Old Aug 3, 2010 | 11:15 AM
Martin//TwistedTuning's Avatar
Coyote
Default base settings
base ignition advance and CO for cossie managed 1600cvh.
need to know so nothing happens on way to MOT and that is passes on emissions
cheers
Old Aug 3, 2010 | 05:39 PM
studabear's Avatar
studabear
ignition advance will be controlled by the ecu map? is on mine, co will need to be under 3.5% depending on age of car, can't remember exact years for the higher limit,
Is your ecu chipped/mapped for a 1600 cvh?
Q reg's are visual check only
Old Aug 3, 2010 | 05:55 PM
Coyote
thought it may have been ecu controlled. so where abouts would i need to set the dizzy or wouldnt that matter too much?
and havent got CO machine, however the bloke next door has as he is an MOT tester so will bung it on that and have a play around.
damn thing dont even idle atm, and all the sensors are DEFINATELY working 100% and loom is brand new and tested.
could be cam timing out by abit i spose
Old Aug 3, 2010 | 08:35 PM
studabear's Avatar
studabear
what ecu are you running, l6 l8 etc
are you running a phase disc or a hybrid distributor?
Is the ecu mapped for a 1600 cvh??????????????????????????????????
Have you set the fuel pressure around 3-3.5 bar
Is the tps set accuratly???????
Old Aug 3, 2010 | 09:11 PM
Coyote
level 6 ecu with pectel board in it
and phase disc, which is set up 100% as had it running yesterday fine
yup, came off a running cosworth managed 1600 on yellows same as mine
checked fuel pressure to be 3 bar with vacuum which it is
and the throttle sensor is as close to dammit i can get it currently.
however as the car was laid back, and there being hardly any fuel would seem logical that it ran crap after i put it down, so could be due to there not being much fuel supplied, if any!
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
3doorcozmess
Sep 7, 2015 01:32 PM
turbowag
Sep 3, 2015 08:07 AM
