idle/running issues
right then the problem i've got is my efi turbo escort wont tick over or rev up, if i disconnect the pipe from the inlet to the map sensor it runs fine but a little fast,if i block the pipe from the inlet it cuts out again.also if i unplug the map sensor aswell as the pipe on the inlet it will idle nice , we tried a cossie 3bar mapsensor on it and it still would not tick over with it all connected , if we disconect the pipe from the inlet it ticks over but fast and if i block the pipe on the inlet it will tick over nice evenwith the map sensorstill plugged in to the loom.
so does anybody have any ideas what could be the problem.
the car is running ofab ecu and is running an xr3i wiring loom which was all running fine when removed from another car but i only got the loom from the other car the map sensor i am using is a webcon one that i bought off fleabay if that makes a difference.
SMILER258
28-09-2015 09:04 AM
