Clutch Release Bearing
If it rattles when pressed, it's the bearing that is worn.
If it rattles when not pressed, it's usually the aluminum input axle sleeve the bearing rides on that has worn and typically generated wear grooves on its surface.
If its the sleeve are they available to be changed?
