Re-fitting clutch and flywheel. New bolts needed?
Wye Valley Hardcore
As above. Re fitting my AP clutch and flywheel soon. Is it a good idea to replace the bolts or are the old ones fine?
I done my recently and used the same bolts as before, did you have your flywheel skimmed or refaced? and are you running a new ap paddle?
if its the same one you had before then just check that there is no glazing to the face of the flywheel and get a metal straight edge to check that the flywheel is flat, also check the condition of the cover plate for glazing and warping it will look a bit like a worn brake disc.
Wye Valley Hardcore
Yeah the flywheel is being skimmed before fitting, and the whole clutch has only done 1,000 miles. Paddles and cover look like new.
Used bolts twice and never had any problems with the bolts, even clutch supplier said they weren't neccassary to replace, will ask mechanic if he used loctite threadlocker though.
jessie_rs
11
03-06-2019 04:57 PM
track.focus'd
12-08-2015 05:53 PM
xr4x4rs
06-08-2015 09:03 PM
hazbaz1984
Ford Focus (All Models)
30-07-2015 05:15 PM
