Another s2 heat problem
Old May 25, 2010 | 06:52 PM
GHAFRS's Avatar
GHAFRS
RSCRAZZY
Default Another s2 heat problem
just bought a G plate in white seems ok bit tatty anyway when car is running al is fine but one warm and turned off couple minuites and she dont want to start any pointers i could have peple will be a great help as its ok when i fill up i cant start have to wait a few minuites then decides to start
Old May 25, 2010 | 06:54 PM
Rob_DOHC's Avatar
Rob_DOHC
naff sensor, small air leak or in need of a setup up, take it some where decent mate and get them to look at it, will save you loads of time and money in the long run!
Rob,
Old May 25, 2010 | 07:04 PM
Chopshop85's Avatar
Chopshop85
Starter motors can be a bit dodgy when hot. Esspecially the excite wire. Worth a look.
Old May 25, 2010 | 07:20 PM
GHAFRS's Avatar
GHAFRS
RSCRAZZY
all wires are new from battery to starter then starter to alt all new also from loom to starter, could do with a tune up but would this effect it as it starts in the morning or left to cool for about 20mins its fine, when on temp then try starting nothing happens turns over no start someone did mention the coil wire from the fuse box ive never had an issue with myself????
Old May 25, 2010 | 07:24 PM
mr_joe0606's Avatar
mr_joe0606
mine was like this when i bought mine just cleaned up the cold start valve and it sorted it. hope this helps.
joe
Old May 25, 2010 | 07:35 PM
Rob_DOHC's Avatar
Rob_DOHC
Yes a set up can sort this,
Mine did this because it was running lean, it started from cold because of the extra juice from the cold start injector... but no when warm. This was caused by 3 things,
Small air leak
Bad coolant sensor
Bad setup (guy i bought it from had just adjusted the CO pot to cover the problem)
I found that if you take the filter top off and whilst some one is cranking the car push the flap down by a mm or two, if yours starts like this your running lean.
Rob,
Old May 25, 2010 | 07:56 PM
juffer's Avatar
juffer
Try what rob has suggested. A friend of mine had to be started by pushing down the flap. My car wouldn't start when hot. Turned out to be the fuel accumilator.
A decent setup will sort out the problems.
Old May 25, 2010 | 09:18 PM
GHAFRS's Avatar
GHAFRS
RSCRAZZY
thanks guys will get it up on the setup have not had a car set up for a while now im from bimingham any good reliable suggestions please
Old May 25, 2010 | 09:35 PM
Rob_DOHC's Avatar
Rob_DOHC
If you take it some where decent they will be able to fault find quickly too
Good luck
Rob,
Old May 26, 2010 | 08:19 AM
studabear's Avatar
studabear
pj motorsport are in the midlands
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Rammer46
Sep 18, 2015 08:31 AM
cossie09
Sep 10, 2015 06:56 PM
BRAM
Sep 8, 2015 07:11 AM
