EFi crank position sensors
Fleet Manager
right im doin a turbo conversion on my xr3i, i bought a frst engine thats got nothing on it but the CPS from my xr3i it like 20mm to long!
ive tryed to take the metal part that holds it off the xr bottom end but it ment removing the clutch and flywheel so didnt in the end
anyone else come across that problem??? will a universal sensor work??? or can i just space my sensor out?
Balls Deep!
You can send it to me!!
lol
Mine is like 20mm too short and I cant find which one i need, XR3i you say?
I had to trim the lug off my Fiesta RST one to make it long enough...
![](http://i413.photobucket.com/albums/pp217/Th3blueroom/IMAG0213.jpg)
My holder looks like this....
![](http://i413.photobucket.com/albums/pp217/Th3blueroom/IMAG0214.jpg)
I have a brand new FRST one (in the picture above the one I trimmed), if yours is the one I need then we can do a swap!![](https://passionford.com/forum/images/smilies/smile012.gif)
How long is it end to end, can you stick a photo up?
Fleet Manager
yer thats what the xr3i holder looks like yours must be built up on xr3i bottom end my new engine which if frst is very shallow
def do a swap with ya i'll get a pic up asap to show u
ford superceded the sensor bush
there used to be 2 types
i think they now only do the one that needs the shorter sensor
sensor part numbers
6502253
6859702
bush part numbers
6176115 <old bush no longer stocked
6477127 <newer superceded bush
sensor part numbers
6502253
6859702
bush part numbers
Balls Deep!
Is that the same as the Granada/Sierra ones?
6502252
6859701
http://www.autocarspare.com/catalog/...r/6502252.html
![](http://www.autocarspare.com/img/1809/6502252_b.jpg)
The part number syou gave Nigel all bring up these shorter ones...
6502252
6859701
![](http://www.autocarspare.com/img/1809/6502253_b.jpg)
Fleet Manager
bush 6176115 with sensor 6502252 upto 15/09/1990
bush 6477127 from 15/09/1990 to current
sensor 6502253 from 15/09/1990 to 15/10/1992
sensor 6859702 from 15/10/1992 to current
Mark RS
12-10-2015 06:01 AM
