FTAO Rick and any other MS users with Bosch 403 Grey Injectors SORTED NOW!
Old May 1, 2010 | 08:08 PM
  #41
Karlos G's Avatar
Karlos G
Balls Deep!
Oh! Is that because of it's high BSFC?
Old May 2, 2010 | 05:17 PM
  #42
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
Originally Posted by Karlos G
I dont know if going bigger will be too much, might start running into trouble with getting a good idle, 630cc is pretty big as it is! lol
Standard Bosch MFI pump as far as I know, if your still at 3bar the fuel pump should not make any difference unless the old one was struggling at high RPM's?
some of the siemens injectors are really good at idle, around the 60Lb area anyhow.
my pump was definitely running out of puff up the power, hence the need for a much better pump, flows at 165Lt/hr, whereas the 910 as common on rst's is only 130Lt/Ht.
apparently rated for upto 500bhp, i think this is a little optimistic i think 350-400 may be more reasonable, bearing in mind the 044 pumps flow 200Lt/Hr.
Old May 2, 2010 | 05:29 PM
  #43
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah i did read that those 630cc's where really good at idle, part of the reason I was looking at them.
My pump seems to be fine, with the Greys in they are only at about 75% where as the old VXR's were hitting 106% at full load! lol
Old May 2, 2010 | 05:33 PM
  #44
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i have no idea how my 440cc ones are doing to be honest, i'm just still getting over fuelling on 16psi of boost, not got the balls to treat the box to 22psi much as it's poorly already.
if they can't cope i'll just hold the power back till after my wedding, only 3 months left to keep not spending on car though
Old May 2, 2010 | 05:36 PM
  #45
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah I didnt think to look until Project rs said he had maxed his VXR's out so thought i'd better have a look... loaded up my most recent log and was shocked to see Duty Cycle 1 hitting 106% @ full load! Promptly turned the boost down a bought some Greys! lol
Old May 2, 2010 | 06:06 PM
  #46
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i've had a look at an old log and i think i need bigger injectors too
not sur eif i'm reading it right, but duty was hitting 140?????
Old May 2, 2010 | 06:08 PM
  #47
Karlos G's Avatar
Karlos G
Balls Deep!
Your fucking joking??? email it over to me and i'll double check!!
Old May 2, 2010 | 06:27 PM
  #48
Karlos G's Avatar
Karlos G
Balls Deep!
Yes mate you need bigger injectors, big time!!
Your are indeed hitting 140% injector duty at 5300rpm, 18.5psi, and are dangerously lean!!!
Looking at your log i'd say around 10psi is about your limit in those injectors, as your hitting 85% at 5100rpm at 10psi, even that might be too much if it holds it to the limiter!?
Old May 2, 2010 | 06:41 PM
  #49
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
as per PM, not getting the same issues since re checking fuel pressure and changing fuel pump.
i would need bigger injectors at some point though.
Old May 2, 2010 | 06:43 PM
  #50
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah thats cool, fuel pressure being low would of made a big difference Sean!
Old May 2, 2010 | 07:01 PM
  #51
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
yeah i adjusted it and something happened with the pressure for sure all my map went ultralean, i had to map it out, which resulted in the DC going mad.
after new pump was fitted and rechecking pressure (which had to go up again for some reason) i pulled loads out of the ve table.
i have been lookng at bigger injectors and may just hold off for some siemens ones, 600cc should keep me safe for a while, odd how a cossie only needs them that big when they are hitting big power, must be down to the BSFC.
me being on a 1.8zvh is different again.
Old May 2, 2010 | 07:14 PM
  #52
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah your still using an 8v CVH head so the BSFC is going to be high, even more so with a 1.8 bottom end.
16v engines typically have a much lower BSFC from what i've read.
Old May 2, 2010 | 07:46 PM
  #53
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
it's daft ain't it lol!
i was informed by more than one person that they would be fine for 300bhp on a zvh, clearly they weren't aware of the DC they were on.
the alternative is a second bank of injectors and a couple more drivers for them, i have spare 375cc ones i got a long while back before these.
Old May 2, 2010 | 08:05 PM
  #54
Karlos G's Avatar
Karlos G
Balls Deep!
Mission! Got to be easier to just buy some bigger ones! lol
Old May 3, 2010 | 04:25 PM
  #55
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
looked for bigger ones and think i'm going to get some siemens deka 60Lb ones, works out around Ł150 delivered from the states new if you look around enough.
maybe overkill, but they have 4 nozzles so mist nicely and will be able to handle more fuel pressure upto 87.5psi if needed to give even more flow.
Old May 3, 2010 | 05:00 PM
  #56
Karlos G's Avatar
Karlos G
Balls Deep!
Thats what i've bought mate, dont think it will be overkill as greys actually flow around 600cc (tested many times) and they are at around 75% @ 21psi on my engine.
Old May 3, 2010 | 05:24 PM
  #57
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
where did you get them from, trying to convince the woman it's a neccessity and i can't just turn boost down lol!
Old May 3, 2010 | 05:28 PM
  #58
Karlos G's Avatar
Karlos G
Balls Deep!
http://www.intengineering.com/Siemen...-p3471089.html
Old May 3, 2010 | 05:34 PM
  #59
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
about the same as the company i found, injectors were cheaper but postage was more, worked out at Ł143 all in so no odds between them.
just wish i had the cash ready, will have to wait till friday and check finances, see if i can flog my 375cc and 440cc ones.
Old May 3, 2010 | 05:38 PM
  #60
Karlos G's Avatar
Karlos G
Balls Deep!
Yes mate, get them up on ebay and on here!
Old May 3, 2010 | 05:40 PM
  #61
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i really do need to sort out membership on here, again more money, bloody wedding sapping all my cash
might just be cheeky and break out the CC till payday.
Old May 3, 2010 | 05:52 PM
  #62
Karlos G's Avatar
Karlos G
Balls Deep!
Old May 4, 2010 | 11:46 AM
  #63
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
I've done it now, they're on their way from same company as you chose, seemed the best deal with the 3-5day postal service, should be here ready for mapping for FITP
Old May 4, 2010 | 01:35 PM
  #64
Karlos G's Avatar
Karlos G
Balls Deep!
Good man Sean!
Old May 4, 2010 | 09:38 PM
  #65
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
race you to fitting and mapping lol.
should be nice to see low DC figures again, can't believe how bad it was, that's what happens when you take your eye off the ball a bit i guess.
still got heatsoak issues effecting the MAT, but running a little richer on idle so at least it's not getting as hot now, runs fine after a minute or less.
Old May 4, 2010 | 10:12 PM
  #66
juffer's Avatar
juffer
After reading this post i seriously think i have under sized my injectors. Im running standard turbo 1600 cvh with cam and stage 3 head. The injectors i have are 380cc @3bar. I have not yet run these so i cant do a recording to send to you. As a ball park figure what do you think boost and power i can run? Im also runnin 044 cossie pump if hat makes a difference.
Old May 5, 2010 | 07:18 AM
  #67
Karlos G's Avatar
Karlos G
Balls Deep!
Hmmmm not much! lol
VXR 480'cc seem to top out around 220-240bhp and 19psi (on my engine).
What turbo do you have?
Old May 5, 2010 | 08:15 AM
  #68
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
as with all the info on injectors it's pot luck whether they can do what they say.
beiges flow at 226cc and they get used all the time for around 200bhp along with a 195 chip, however what is worrying is that they shouldn't even be able to run safe at that level.
in fact on a turbo engine not running monster power they should only be able to push out around 47.5bhp each, so a total of 190bhp and that is a well tuned engine with a BSFC value of 0.42.
but as we learn a lot of engines with levels of mild tune don't return that value, so knock it down a step to a BSFC of 0.47 and you get 42.4 bhp per injector, so only a total of 169.6 bhp and i'm taking the 95% duty values which isn't ideal as you really want to have a max of 80% to allow for variance in air and engine temp to fuel adequately across the ve tables (this would now be 35.7bhp per injector)
think about an even worse engine with a worse efficiency, the rs turbo engine as standard for instance could possibly have a BSFC of 0.52, you can see where this is going, for a safe setup this is roughly where you want to be planning an engines fuelling with duty cycles of 80%:
32.3bhp per injector now, total of 129.2 bhp, this is for a lightly modified engine.
i've done this little write up to show how inappropriate injector sizing can be sometimes and that there is little room for movement on some setup, in this case beige injectors really are pushing their boundaries on a daily basis when fitted with a 195 chip as a package.
to put things into perspective the 60Lb injectors myself and Karlos have chosen will flow enough for a duty cycle of 80%, fuel pressure of 3BAR (these can run 6BAR salefly though) and a BSFC of 0.52 for the worst cas escenario will fuel enough for 92.3bhp per injector, enough to fuel our engines at a minimum of 369.2bhp, this is taking safe calculations etc.
look at the bottom of this link to show the flow rates and power output of a particular size of injector:
http://users.erols.com/srweiss/tableifc.htm#ITABLE
Old May 5, 2010 | 08:50 AM
  #69
DazC's Avatar
DazC
Sean, bear in mind that you will never be able to run much past 3 bar static base fuel pressure. At most you'll be able to run 4 bar atmospheric.
Old May 5, 2010 | 08:52 AM
  #70
DazC's Avatar
DazC
That comment was based around a absolute max boost ceiling of 28 psi by the way.
Old May 5, 2010 | 09:10 AM
  #71
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
totally, that's another factor of course and talking pressure differential of one side of the injector to another.
say we're on no boost, then you can run injectors at 3BAR (43.5psi), then say we chuck in 20psi of boost, then the differential across the injector must still be 43.5psi, so we need to get 63.5psi of fuel pressure into the injector to compensate the pressure change.
Then say we chuck 30psi of boost into the mix, then we'd need 73.5psi of fuel pressure to keep the same differential to keep fuelling linear, which a rising rate fuel pressure reg should do.
the problem is making sure the fuel pump can cope at this level, hence the need for uprating them.
i noticed a big difference when going from an rsturbo pump to my 979 pump, flows a lot more and handles higher pressure better, i actually pulled ve values out of my table when i did this. my next pump would be the 413 (IIRC) 044 type pump or a walbro 255 one if i have any fuelling issues again up the revs/boost.
Old May 5, 2010 | 04:36 PM
  #72
juffer's Avatar
juffer
Hmmmm not much! lol
Im running standard turbo 42/36 but want to upgrade to 42/48 at a future point.
Old May 5, 2010 | 04:41 PM
  #73
Karlos G's Avatar
Karlos G
Balls Deep!
Then I would say around 12-14psi, but with your head and cam I doubt your stock turbo will hold any more than about 12psi to the limiter anyway as that is your restriction right now, good for about 190bhp'ish.
Old May 5, 2010 | 05:09 PM
  #74
juffer's Avatar
juffer
ok. Im realy confused now lol. Have i missed something when i used this equation to work out my injector size?
http://www.area-six.co.uk/Performanc...l%20system.htm
According to that calculation my 380cc injectors should be able to cope with 81 bhp per cylinder.
Old May 5, 2010 | 06:37 PM
  #75
Karlos G's Avatar
Karlos G
Balls Deep!
It's wrong lol At least for our engines anyway...
Based on that your BSFC is about 0.35 which is crazy!
I think our BSFC is much higher than that because my estimated bhp is around 220-240bhp and my 480cc injectors where at 95% duty which puts my BSFC at about 0.67!! lol
Old May 5, 2010 | 06:42 PM
  #76
juffer's Avatar
juffer
BSFC?
Old May 5, 2010 | 06:48 PM
  #77
Karlos G's Avatar
Karlos G
Balls Deep!
Brake specific fuel consumption... the amount of fuel an engine needs to produce 1hp.
The more efficient the engine the lower it will be, the less efficient the engine the higher it will be.
Old May 7, 2010 | 03:26 PM
  #78
Karlos G's Avatar
Karlos G
Balls Deep!
I win!! lol
Fitted my Deka's today and all is well again!
Went out and did a little bit of mapping to get things close to where they need to be up to about 16psi, injector duty was peeking at about 59% so plenty of fuel left for whatever boost I want to run!
Old May 7, 2010 | 11:07 PM
  #79
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
damn you!
mine are somewhere in transit still, they left sanfransisco two days ago!!!!! lol!
glad they are good for you, i really want to get them fitted and enjoy knowing i've got a decent safety margin
Old May 7, 2010 | 11:10 PM
  #80
Karlos G's Avatar
Karlos G
Balls Deep!
Mine took 4 days to come so hang on a bit mate!
Yeah nice to have plenty of overhead!
