This is what happens when your lambda loom gets cought round your wiper motor...
![Angry](https://passionford.com/forum/images/icons/icon8.gif)
.... ![Wall](https://passionford.com/forum/images/smilies/wall.gif)
![](http://i413.photobucket.com/albums/pp217/Th3blueroom/IMAG0238.jpg)
Then you fix it.....
![](http://i413.photobucket.com/albums/pp217/Th3blueroom/IMAG0239.jpg)
... and this is what happens when you dont fix it properly...![Wall](https://passionford.com/forum/images/smilies/wall.gif)
![](http://i413.photobucket.com/albums/pp217/Th3blueroom/IMAG0243.jpg)
![](http://i413.photobucket.com/albums/pp217/Th3blueroom/IMAG0244.jpg)
Needless to say I have a new one now![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Also fitted my Greys today too, so plenty of fuel available now
![](https://passionford.com/forum/images/smilies/roi.gif)
May have a CTS 2+ sorted, fella on here bought one from Dave Moore Editor of Perfomance Ford and has not fitted it, going MTX instead, so I should be buying that.
It does seem that I have some bad luck doesnt it!?!!
I just put these things down to it being a learning curve.... when you build, wire, and map your own car all from scratch for the first time there are a lot of little things that can go wrong that you would do differently the the next time.
Which is why I always post everything up so other people can learn from my mistakes, and also from the few things I've discovered or overcome myself!
Bananas!
LMAO ![Wall](https://passionford.com/forum/images/smilies/wall.gif)
Which is why I always post everything up so other people can learn from my mistakes, and also from the few things I've discovered or overcome myself!![](https://passionford.com/forum/images/smilies/roi.gif)
just feel for you as its like nearly everyday lately that you've had another set back, you must be dying to drive her for fun and fun only.
Bodger of Blackburn
bad times that, lesson to learn is that something will get tangled if it's not secured away.
i had this on my steering column under the dash, filled car with smoke and burnt a lot of wiring out.
needless to say i'm more careful now and use fuses all over.
glad that the greys are doing well, i found my rs turbo pump was getting rubbish, now changed to a 979 pump, that's between the 2wd cossie and 044 pump in the range, i've had to pull PW out of my ve tables now, really holds the pressure better as flow increases.
..BS Motorsport..
had very similar happen on mine, mate was driving it to national day for me and rang me to say wipers had packed up, he opened bonnet to see a big multicore wrapped around mechanism just like yours as. Luckily the cable wasnt made off yet, i'd passed it through bulkhead whilst dash was out to use at a later date so no drama really. Nice scorch marks on that circuit board!!! Keep at it Karlos, really is turning into a saga this car of yours! Glad mine aint running when I read about all these problems!
The Youth.
30-09-2015 09:59 PM
muz
30-09-2015 08:29 AM
SMILER258
28-09-2015 09:04 AM
