Skimming pistons advice!!!!
Ive got a std set of mahle pistons dont no if its a good idea but i no u can get them skimmed to lower comp has anyone done this before and how much was taken off and what comp ratio does this make them???
I no this aint best way to do it
cheers
jon
cheers
jon
Originally Posted by Rallyesport
You can skim new pistons, but old pistons are not up for skimming. Why do you need to lower the compression? What kind of boost are you planning?
ye u can skim them, mine are mahle low comp ones, but the compression wasnt low enough so we took of a wee wee bit more
i was looking at pistons for a 2.1 zvh conversion...i heard with normal mahle mistons its 8.2.1 i fink however machined a little its 7.5.1 ....i may be wrong..
i would like to run around 20 psi so what would be the best compression ratio and what pistons??? i heard accrallite are the top ones to buy..but is there a use lashing out that much money??
at the end of the day 20 psi would be quite alot and reliabilty will be dependant on the mapping more than anything but what other mods would you carry out on the engine for further reliablity?
many thanks
many thanks
you can run 20psi on std comp with a good intercooler! and maybe just to be really safe water injection! im hopeing to be runnning 18-20psi on std pistons and rods come friday!
I ran 26psi on standard comp, standard rods & pistons and never had any problems......although I do have a very efficient intercooler & loads of fuel !
I now run 15psi as I want the engine to last as long as possible
cheers, Duncan
cheers, Duncan
cheers, Duncan
cheers, Duncan
11psi drop! how much power ya loose for that?!
I also tried my Orion with 30psi and standard S1 bottom end. Seemed to be just fine with LOADS of power. I now have it at 22psi for daily use to get to work and back.
many thanks
many thanks
focus rs 1672
[quote="james_birch"]you can run 20psi on std comp with a good intercooler! and maybe just to be really safe water injection! im hopeing to be runnning 18-20psi on std pistons and rods come friday!
Sod it keep them std then i think was only going to run about 15psi to start with but i no i will get bored an turn it up
got a big intercooler GRS so should be up to it
Lot a good my post about this was as just been down to see about my engine an have been told need a rebore so std pistons no good now need to be about 1mm overbore better get me wallet out
alan told u that u need a 1mm overbore aswell!, same as daves and mine then, 1mm pistons are hard to get hold of if u want low comp, mahle said they dont do 1mm anymore, got mine from P.T.S mate, 01582 731733
Get ya money out!!.
Get ya money out!!.
High boost on standard compression is no problem as long as the ignition is spot on and the fueling is good. Lowering the compression will make the engine even more dead at low revs.
rsguy
44
29-09-2015 03:29 PM
deathrider666
28-09-2015 06:12 PM
