Help s1 rs holding back on boost(under load)
car holds back on boost, will rev fine on the spot and sounds nice but as soon as turbo spins up at around 3000 revs (at the point its suposed to kick in hard) it holds back and makes a kinda backfire burble noise and wont accelerate through it?
the only second hand parts on the car are,
turbo (slight play in shaft to be expected)
acctuator (-31 good tension)
amal valve has a little plastic restrictor type bung on c side of it.
camshaft
dizzy
everything else is new, any ideas????
camshaft
dizzy
CabrioTurbo
01-08-2015 11:04 AM
