rs turbo lsd diff
Old Feb 23, 2010 | 08:23 PM
red rsturbo's Avatar
red rsturbo
Default rs turbo lsd diff
how hard is it to remove and replace diff in a mk 4 box?
Old Feb 24, 2010 | 05:49 AM
cabrst's Avatar
cabrst
depends on how handy you are...
you need to take the Gbox apart, then its just a matter of change it, but you may aswell change the bearing aswell while you have it apart..
And check the mainshaft that it aint damaged..
Old Feb 24, 2010 | 05:59 AM
bythomson's Avatar
bythomson
just done this at college really more scary then anything just keep all components laid out in the order they came off and take your time and its quite simple really . take pics step byy step to keep you right
Old Feb 24, 2010 | 08:16 AM
Matthew_M's Avatar
Matthew_M
getting 5th gear off is the hardest bit
i put a lsd in a diesel box many moons ago
if your putting a diff in a box that never used to have one make sure u change the speedo drive aswell or u will end up stripping the teath off both the speedo drive and the gear on the lsd
found this out the hard way :'(
Old Feb 24, 2010 | 09:09 AM
XR2's Avatar
XR2
Here you can see pictures of the BC boxes:
http://www.zetecinside.com/xr2/gearbox.shtml
http://www.quantums.info/gearbox.htm
The really hard part of the work is getting all bits back into the bellhousing and the gear selector mechanism working properly. Not really a job for someone who has never done that before...
Old Mar 16, 2010 | 06:42 PM
Antti O's Avatar
Antti O
Hi
My lsd wont work as it should. Is somewhere instructions for diff maintenance?
Old Mar 23, 2010 | 05:32 AM
Antti O's Avatar
Antti O
Anyone? I know gearboxman.co.uk already but they only sell reconditioned units.
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
xrmalin
Sep 13, 2015 06:52 PM
kevin36
Sep 2, 2015 06:24 PM
