1600i rocker, will it go straight on s2??
Git a 1600i rocker cover for my car which i have had powder coated.Wanted to check with you guys if it will fit straight on as when you look underneath it has a divide running through the middle so is on to halves where as the standard one doesnt? Also it only has a breather outlet on the rear right not on the left so would i need to add one?
here's a picture to show what i mean.
the two silicon hoses at the back are connected and go off to the breather.
need to remove the middle breather and re-route the charge carrier think there is a small breathe to weld up 2 did mod one up for my old s2 but never used it
need to remove the middle breathe anyway from what i can remember becase it will sit right up to the inlet. i have one all done somwhere ill find it so i can see how i modded it. think i removed the middle breather and some of the top fins behind the ford motorsports badge
When you turn your rocker over does it have two channels that the centre breather runs to tho?
they do fit but i think weather or not they fit straight on depends on what inlet manifold you use, i use a 16i inlet as well and mine fits straight on
i'v got mine going to the inlet manifold as there is an outlet for it, got the right hand 1 to the block, middle one to the breather pot, then the tiny 1 in the middle going to the inlet manifold, failing that just blank it off.
my partner has one on his XR2... does anyone have a spare filler cap they wanna sell?? he needs new one .. the other went missin...
a propper one will fetch silly money if its in good nick, just get 1 off a volkswagen engine, that'll do the job untill you can find a propper one.
deathrider666
28-09-2015 06:12 PM
chris m1
07-09-2015 08:02 PM
