meterin unit...
Old Feb 11, 2010 | 03:39 PM
brett_'s Avatar
brett_
Default meterin unit...
wot that best way to find out if this is workin???
as this is last thing i can think off thats stoppin my cabby turbo from startin...
cheeRS brett
Old Feb 11, 2010 | 04:14 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Brett,
It seems that the 'g' button might be faulty on your keyboard??
Old Feb 11, 2010 | 04:46 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Originally Posted by Christian and Beccy
Brett,
lol
Old Feb 11, 2010 | 05:04 PM
brett_'s Avatar
brett_
Brett,
yh now im lost...
Old Feb 11, 2010 | 05:05 PM
brett_'s Avatar
brett_
Originally Posted by S1 JOHN S1
In what way working?
Fuel delivery?
Turn it on prime pump and then undoe the bolt on the metering top if it's leaking u have petrol
Check the return line isnt blocked better yet you can if u have an air line blow through to clean any possible blockage
Last thing is the air return unit thingy i fitted one to mine and it wouldnt fire as it wouldnt prime out the air or something! That's fitted to left side of the metering unit as u look down
ta mate, irl have a look 2moro
Old Feb 11, 2010 | 07:19 PM
Christian and Beccy
#1 in Spelling Club
Brett,
Originally Posted by brett_
yh now im lost...
Hope this helps.....
wot that best way to find out if this is workinG???
as this is last thing i can think off thats stoppinG my cabby turbo from startinG...
cheeRS brett
Old Feb 11, 2010 | 07:28 PM
Rob_DOHC's Avatar
Rob_DOHC
lol!
take an injector out, stick it in a jar.
turn the ignition on
with the air filter off push down on the large flap
if fuel squirts into the jar at a rate dictated by the flaps position its a good indication that the metering unit is physically 'metering' the fuel.....
if above goes to plan look elsewhere for the problem
Rob.
Old Feb 11, 2010 | 07:35 PM
brett_'s Avatar
brett_
haha wot you get for bein a chav lol
Old Feb 11, 2010 | 07:43 PM
jn_rowe_uk's Avatar
jn_rowe_uk
amazing, i was going to write a message regarding the metering unit
I am pretty sure that mine is on the way out
Does anyone know where i can get a replacement for my series 2???
Sorry to hijack the thread
Thanks
Old Feb 11, 2010 | 07:50 PM
Rob_DOHC's Avatar
Rob_DOHC
Sorry dude but not many places at all recon them, you can't get them new and if you can get a recon or a new one you will pay the world!
When you say its on the way out what do you mean? metering units get a bad rap, but often its other bits that are 'telling' them to do the wrong thing.
Rob,
Old Feb 12, 2010 | 11:38 AM
jn_rowe_uk's Avatar
jn_rowe_uk
well i tested the fuel from the fuel pump under the fuel tank to the front of the car- good
Fuel from the pump to the metering unit-good but then from the metering unit to the injectors - nothing
This is why i assumed its the metering unit that is going?? i cleaned the unit and the air return next to it and car nows runs but for how long??
Old Feb 12, 2010 | 02:32 PM
jn_rowe_uk's Avatar
jn_rowe_uk
It's the air unit that allow's the fuel injector's to prime mate so if that's cleared now and ur running it should be cool
Oh really, ok that sounds good
Have been told by a few people that the metering unit are pretty bullit proof
Will start driving the car again
Thanks everyone
James
Old Feb 12, 2010 | 09:49 PM
jn_rowe_uk's Avatar
jn_rowe_uk
thanks for the comments mate, appreciate it
Old Feb 14, 2010 | 05:15 PM
4u2nvrs's Avatar
4u2nvrs
did you get to the bottom of this problem as im have the same troubles
Old Feb 14, 2010 | 07:25 PM
jn_rowe_uk's Avatar
jn_rowe_uk
well my car seems to be running fine now, took it out the other day and no problems at all
Old Feb 14, 2010 | 08:04 PM
Turbo Al's Avatar
Turbo Al
another hijacker!, see the 3 pin unit on the side, i took that off and pulled the rod out, whats the best way to set the 2 fragile contacts on the main rod holding the flap in place if that makes sense?
i see the cover is adjustable to but i can put that on its original marks
Old Feb 15, 2010 | 05:45 AM
Turbo Al's Avatar
Turbo Al
tried that, no reply?? i got a shot of a unit, the car wouldnt even fire and the unit moaned at me when i turned the ignition on and winding over.
didnt want to fiddle with it as it wasnt mine.
the problem with mine was the lever for the co adjuster had unclipped and was swinging loose on the main pin holding it all together
Old Feb 15, 2010 | 07:12 PM
Turbo Al's Avatar
Turbo Al
ha cheers
went to put mine back together and the flap is drooping now, duh?
will strip it again the morn or will fuel pressure raise it back up??
any of that 3 for sale?
G950KDT
Dec 20, 2009 03:10 PM
shaun_rs
Mar 25, 2009 08:19 PM
TuRbO-CaB-LaD
Jul 10, 2008 02:30 PM
TuRbO-CaB-LaD
Jun 19, 2008 07:46 PM
