which box is best/strongest for a 300hp s2.mtx ??
I'd say focus RS, more pricey but comes with a quaiffe diff and is oober strong. It's easy to mount, Gear cables are easily fitted, loads of clutch choice. The tricky bits are hydrolic clutch pedal and electronic speedo. I've used an RS2K box but its a hore to mount in comparison, clutch choice is poor and gear selectors are not much fun either! All the mtx's have good points and bad.
sorry to hijack the thread but im planning on fitting a focus rs box on my zetec turbo hopefully in a few weeks, can i take the cables and lever etc....from a standard 2.0l focus and use them on my box for the conversion?? any info would be much appreciated
yes just make sure you get them of same car and the lever will bolt straight up you just need to make a round hole for the cables to go through, the clutch is hydrolic aswell so if you need any idvice let us know but is easy to do
you asked about mtx the 6 speeder is not an mtx and you need to move your brake servo aswell as mounts/shafts/hydrolic pedal only thing you save on is cutting inner wing but it's got no diff and clutch flywheel combo's are harder to get
Got you, sorry i didnt realise.
worth a go can't see them having one special made for rs box, all i've seen in ford range all look the same just some plastic outlets and some metal
Surrey RSOC Photographer
Add
Steve Escos
01-10-2015 06:57 AM
deathrider666
28-09-2015 06:12 PM
Russ Payne
25-09-2015 08:29 PM
