how to fit T3 manifold heat wrap
recently bought heat wrap for for my t3 manifold ,IS there a certain way of fitting it or do u just go for it and hope for the best? any tips would be great !!!!!
wrapping the manifold is a right pain in the arse. theres a bolt hole in the middle at the bottom which is impossible to get to afterwards and its also really hard to do a neat job.
i did mine and it didn't do much but after i took it off and wrapped my downpipe after the turbo until past the gear selector it made a difference tun underbonnet temps on mine. Some people will tell you about cracking the manifolds too, but i dunno bout that. never had a prob when mine was done.
as said though, start off with a double wrap around then go on an angle, go about 50% the way across the width, that way every bit gets wrapped twice.
don't forget to get it it wet to make life easier and wear gloves or you will be itching for days lol
also, prepare for a torrent of smoke when it warms up- it suprised me thats for sure
when i did mine, i found it easier to start about an inch away from the flange and wrap once the wrong way then go back up the manifold, then the end of the wrap is hidden under the rest and it looks neater, boy did my arms itch though
09-10-2015 07:38 PM
track.focus'd
12-08-2015 05:53 PM
