Little update.....
Old 08-11-2009, 06:55 PM
  #81
jamieRST
jamieRST's Avatar
but it doesnt matter if your chasing power figures and cant say theres no point unless youre pushong 250bhp plus.jim hearne had a zvh with a big valve head (inlet) and properly flowed etc running a pretty much standard spec made 226 atw thats 260+ at the fly.sean richardson 220bhp zvh,added a big valve modified head and made 300bhp.fast road/race spec mk4 xr3is have proper modified heads and they dont push 250bhp.
Old 08-11-2009, 08:19 PM
  #82
bad boy rs
bad boy rs's Avatar
good read this learnt a thing or 2
Old 08-11-2009, 08:36 PM
  #83
Chris69
Chris69's Avatar
I just hope your learning from the right posters and not all of it
Old 08-11-2009, 08:41 PM
  #84
jamieRST
jamieRST's Avatar
so who is wrong and who is right then?and why
Old 08-11-2009, 08:46 PM
  #85
Karlos G
Balls Deep!
Karlos G's Avatar
Originally Posted by jamieRST
but i am not on about a massively ported,badly worked head.here is some info ive found for you too.Most 2 valve per cylinder heads are capable of being modified for between 10% and 15% power increase without increasing valve size. Some heads, like the CVH, have even more potential and 20% is possible.Properly done with due consideration for port sizes and valve seat profiles, a modified head will increase power throughout the rpm range. Low and mid range torque increase significantly as well as peak power.The exhaust valves are actually far too big as standard. 37mm is a huge exhaust valve for a 1600cc engine. The 2 litre Pinto has 36mm ones, Peugeot 1.9 Gti are 34.5mm, Golf Gti even smaller. Under no circumstances fit larger exhaust valves and any tuning firm that does this can be safely avoided as they have no clue how to modify this engine properly. There are certain things that absolutely must be done to portshapes to get the CVH head to flow to its full potential. The area around the valve guide where the port bends is critical and this must be straightened out and shaped to blend nicely into the valve throat. You MUST remove the valve guides to get at this area so any head which just has a bit of polishing and no real constructive port work will not show much of an improvement. That means most off the shelf heads you are likely to buy. Every head I do has the guides removed first so that the ports can be modified to the correct shape for high flowThere are some very common misconceptions out there about tuning turbo engines. In particular whether improving flow through cylinder head and induction system porting makes any difference to power or whether all you have to do is turn the boost up. The simple answer is that improving flow can be even more important on a turbo engine than a normally aspirated (N/A) one. All engines make power in proportion to the amount of air they can breathe and anything that increases air flow into the cylinders increases power. To generate a pressure difference there has to be a resistance to flow. Try blowing as hard as you can through a straw and then do the same just through your open mouth. You can generate enough pressure through the straw to puff your cheeks out and almost no pressure without the straw. The amount of airflow is much greater without the straw of course. All the pressure rise is telling you is that there is a resistance to flow but it doesn't tell you how much flow is taking place. The same thing applies to a turbo engine. What the boost gauge is telling you is how much pressure it takes to generate a given amount of horsepower through the restriction of the head and induction system that the turbo is pushing against. If you reduce the restriction you'll get more airflow and power at the same boost level or alternatively the same amount of power at a lower boost level.a big valve head with the correct spec,is good imo
LMAO
The first part of that came from the pumaracing website and he is talking about NA engines not Turbo charged CVH's!!!! Hence the comparisons to Pinto and Golf GTi engines!!
It's totally different for turbo charged cars!!
The second part that you quoted from elsewhere is correct and as it says, a big valve head is good if the engine is properly spec'd..... ie: has a big enough turbo to make use of the available extra flow....... so as I said, slapping your big valve head on a stock enigne will gain you nothing but lag!! As per my graph
ZVH's MUST have a big valve heads or they run out of steam by 5500rpm because the their too restrictive!
So non of that has any relavence to out little turbo charges CVH's mate
Read the article I put up and learn about how it works for turbo charged applications......... in case you do not know it was written by one of the most reputable tuners in the country who also happens to be the creator/owner of this very forum
Old 08-11-2009, 09:14 PM
  #86
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
i agree with everything but the zvh bit, the zvh turbo won't need anymore flow than a cvh turbo, for a given amount of power/airflow through the head. although higher power can be achieved at lower boost than the cvh, so becomes apparent at lower boosts.
Old 08-11-2009, 09:21 PM
  #87
Karlos G
Balls Deep!
Karlos G's Avatar
It needs a lot more flow because of the larger displacement (ie: 2000cc not 1600cc) so at around 5500rpm a ZVH will run out of puff unless it has a big valve head, cam, and a big turbo, thats a proven fact many times over, and why to get the most out of a ZVH you need a fairly big wallet, exactly why Jamie's examples above all have big valve heads, and why a lot of people will recommend either a good CVH build or a full ZT, not the ZVH.
Look here.. https://passionford.com/forum/ford-e...tec-turbs.html
Old 08-11-2009, 09:22 PM
  #88
Chris69
Chris69's Avatar
god, you really don't know do you
at least read the article and stop trying to compare results from completely different applications to the tuning of a 1600cvh turbo.
cvh and zvh's are different engines and require different paths to tune each respectively.
One way of tuning one engine will not work across the board.
the principles are the same but the tuning characteristics of each engine is different- if you cannot see that then this really is going nowhere.
Old 08-11-2009, 09:27 PM
  #89
Karlos G
Balls Deep!
Karlos G's Avatar
The ZVH needs a very very good head (Stage 3 big valve etc..) or it is restrictive and you'll make peek power at 5500rpm as said, you also need a big turbo as a stock T3 is next to useless on a ZVH.
Take alook at this
But to get that result you need to have a big budget and this spec!
2.0, H beam rods, Custom Pistons, CVH 8v Area-Six Big valve head, Custom camshaft, Solid Followers, Area-six double valve springs, Custom Inlet manifold, T38 turbo, Pectel T2 ecu
This is why...
The ability of a turbocharged engine to rev to high rpm's is based primarily on two factors.
1. strength of engine which also encompasses design to be correct for such an application
2. Ability of the engine and turbo to flow sufficent air at these rpm's in order to maintain torque. (this is what makes an engine feel revvy)
The reason the turbocharged ZVH normally suffers with holding high rpm torque is its rated capacity in comparison to the cylinder head flow rate. Essentially this means that the head itself becomes a flow restriction in relation to its capacity and hence engine torque falls quite rapidly with rpm. This can be overcome to some extent with a larger turbo and heavily reworked head which can help increase engine breathing at higher rpm's but this does of course lead to the usual lag, drivability and most importantly cost issues that come about in building an engine capable of using such a large turbo!
hope that helps explain things a little!
The above quote is from Karl Norris of NMS
Old 08-11-2009, 09:50 PM
  #90
jamieRST
jamieRST's Avatar
ok well ive had enough now.more airflow into the cylinder equals more power,end of.yes if you modified your head badly and had huge exhaust ports and low comp pistons,it would be laggy as fuck. There is no difference reharding headwork on n/a and turbod cars as its all work on the block essentially,and the turbo only works on what the engine produces,your quote of needing a bigger turbo to have bigger valves and porting,doesnt make sense as having a properly speccd head would allow the same power at lower boost,therfore you wouldnt need a bigger turbo,again unless it was bad work on the head or a bad spec.its engine,then the head that feed the turbo,which then feeds the engine again,not the other way round.
Old 08-11-2009, 09:54 PM
  #91
jamieRST
jamieRST's Avatar
its the adding the large turbo that causes the lag.and it says there that the problem can be sorted having a reworked head.
Old 08-11-2009, 10:12 PM
  #92
Karlos G
Balls Deep!
Karlos G's Avatar
Well I was just trying to help mate, not to worry!
Old 08-11-2009, 10:23 PM
  #93
jamieRST
jamieRST's Avatar
its ok m8,we will just have to see my results at the end of it.we both have our different opinions and evidence to prove/disprove each other,so we will leave it at that now.anyway glad yours is getting fixed and nearly back on the road,sorry for the hijack.
Xindi
Ford Classics & Vintage
17-05-2008 07:09 AM
Quick Reply: Little update.....
