radiator ??
well at the moment i have a airtec alloy rad but its bit damaged and seems to be makin high underbonnet temps so been advised by few of you to use a std rad but where can i get one from as fords dont do them anymore ? has anybody else had problems with alloys ones ?
Take it to a radiator specialist- they can test it for you and most places can weld and therefore repair it if it damaged.
im going though a few rads at the moment,radtec and a grh,both havant lasted well,so there must be a problem,im looking to swap the upper and lower hoses with ones that have some give/bends built into them and i better check my engine mounts too while im at it.......
yeah i thought bout gettin it repaired but was advised that the orignal copper ones are much better anyway just dont know where to pick one up from
I've got a Ł330 Pace rad fitted to my car about 5 years ago which has done about 30k still in tip top condition and haven't had a single problem with it so far.
